What are you 2011 Mod plans?
All four cross drilled Rotors $250
Front tire rods and drag-link Lamforder $220
http://www.partsgeek.com/gbproducts/...ek+Google+Base
Oil Change $100
New headlights http://www.danielsternlighting.com/ $55
Install the HID yellow fogs I have sitting around $Free
LED rear plate lights $36
Eurocharged Tune $500
LED Running lights $150 going to custom fit them into my Fog-light housing, just want a different look than every other C43 http://umnitza.com/umnitza-aries-mer...ht-p-5830.html
S600 Grill $75
That is just this month and the rest ill fish this summer.
I think my car would look amazing with quad C63 tips coming out the back. This isnt the exact same as our cars but its the same M113 engine with the quad Magnaflow 14826 setup, I think it sounds pretty amazing. http://www.youtube.com/watch?v=wJiGO0f1eWQ
This is Magnaflow with res deleted, 200cel 2nd cats, with 3" pipes from the 200cels back. I think id rather go full straight pipe to the quad set up w/no second cats at all, should be very loud and free flowing. Maybe even 2.5" all the way back to keep the back pressure?
http://video.google.com/videoplay?do...16758803131322
Anyone good with photoshop?
Take these
And put them here
and because i cant find a decent place that sells the rieger
Oil Change $100
S600 Grill $75
pm about those led running lights, im interested too
.Picked up the einsenman for $970.00 and the kw varient setup for $1300.Want to go with 18's poss monoblocks or a three piece wheel nt sure....and tires going with the hankook ventus evo 12,unbelievable tires for the price.
Ok Here is what I am about to start this weekend.
SLK55 6 PISTON CALIPERS, EVOSPORT 360MM 2PIECE ROTORS AND CUSTOM BRACKETS.
DIRECT BOLT ON.
SLK55 4 PISTON CALIPERS 330MM OEM DRILLED ROTORS DIRECT BOLT ON.
W210 LED MIRRORS JUST WORKING ON THE WIRING .
AMG ILLUMINATED DOOR SILLS.
18''WHEELS THAT WILL FIT THE 360mm ROTORS AND CLEAR CALIPERS . SHOULD GET THESE TODAY
ALREADY LOCATED THE HPS1 SUPERCHARGER.
EURO SPRINGS ALREADY INSTALLED.
ALSO INSTALLING CUSTOM PROJECTOR IN THE OEM HOUSING.
HID IN OEM FOGS.
DIRECT BOLT ON.
HID IN OEM FOGS.
http://video.google.com/videoplay?do...6758803131322#
My plans for 2011....to have my 202 running with the 5.0L and to graduate college for the 2nd time...lol.
Oil Change $100
S600 Grill $75
Apart from that, nothing says you can't get one and cut down and fettle so as to fit the 43. Could be cheaper to buy on of the replicas you can find on the net. Just check they are good quality. Search around this forum for that info https://mbworld.org/forums/c36-amg-c...install-2.html
heres the phone number for the place in CA for the rotors, you can ask if her to look at my order, Kevin in indiana let me know if she needs more info 562-434-5670
remember these are not stock but i like em
