Rear Tire Wear, What to Replace First...Looking for Experts
Old Jan 30, 2011 | 03:24 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Hey guys,
My passenger rear tire is wearing very bizarrely. I get the car aligned often, but it's always this side that is the issue. It wears not on the very inside edge, but the inner quarter-way point if that makes sense. If it helps my steering wheel needs to be turned more and more right the faster I go.
What should be my plan of attack? Should I try swapping to new rear lower control arms? Should I replace all of the arms in the rear including the tie rods, etc? I just want this fiasco of burning through tires to end. It's not hydraulic related and it's not height related. It only occurs on the passenger side.
This is a recent phenomena within the last year. Thanks.
Old Jan 30, 2011 | 11:54 AM
Jasssc's Avatar
1996 Mercedes C36 AMG
there are numerous reasons for uneven tire wear
check this out:
http://www.aa1car.com/library/tire_wear.htm
i'd try and diagnose the problem as closely as possible before replacing parts at random
Old Jan 30, 2011 | 01:03 PM
KJI3jflarryfe93's Avatar
interesting buddy.
thanx
Old Jan 30, 2011 | 06:08 PM
OCKlasse's Avatar
MBworld Guru
I saw that link when google searching, but I was hoping for a little more insight. Thanks
Old Jan 30, 2011 | 06:17 PM
ohlord's Avatar
Are you
pulling our legs?
It is height related,look at that drop and the negative camber
plain as day it has got to be -4
it is putting tremendous stress on the arms and the bushings and the tires.
No link or camber bushing is going to correct that without major work.
You do have links installed don't you?
Old Jan 30, 2011 | 06:38 PM
OCKlasse's Avatar
MBworld Guru
It's not height related. I've had hydraulics for almost four years and it's only been an issue within the last year.
133,000 miles and I've never replaced anything in the rear. The front has been taken care of and there is nothing wrong there.
Old Jan 30, 2011 | 07:34 PM
ohlord's Avatar
Okay
I'm sure your'e correct then.
Old Jan 30, 2011 | 09:09 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Can you please post a pic of the tyre off the car, are any of the other tyres wearing abnormally?
Old Jan 30, 2011 | 10:28 PM
OCKlasse's Avatar
MBworld Guru
I am. Thanks.
I'll try to get a pic tomorrow. Issue is only with the passenger rear, thanks.
Old Jan 31, 2011 | 03:34 PM
bagelsjustbagel's Avatar
In search of W222
Fat passenger?
