255/35/18 too big?
Old Feb 11, 2011 | 09:08 PM
99CEEFOURTHREE's Avatar
99 c43,90 mustang gt supercharged convertible,07 acura tl type s, Hummer H3t pickup
255/35/18 too big?
Going with 18x9.5 in the rear with proper offset.Tire rack suggests 255/35 18 rear tire.Will these fit without issues? I plan on lowering the car with voghtlands and pads to give a raked look...any suggestions/reccomendations? thanks!
Old Feb 12, 2011 | 12:42 AM
eddie_b's Avatar
98 c43-sold, 05 Audi A4 avant
That's the size I'm running. I'm on Eibach lowering springs also.
Old Feb 12, 2011 | 02:31 AM
tasho3's Avatar
2014 C63 Sedan
i have had that size for over 3 years now and never had a problem, i even 265/35/18 at one point and still no problem. so you should be good!
Old Feb 12, 2011 | 12:29 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Thats what I have on but when I had the H&R's I had to roll the rear fenders. Don't know if you'll have that issue or not. Everyone else seems to be fine. Now with the Votlands I'm have rubbing issues on the drivers side front with the 225-40-18's. gonna try the #5 pads,right now I have #4's.
Old Feb 15, 2011 | 08:40 PM
popey24's Avatar
C43 AMG 5.5 - 396.4HP
Depends on your offset and on the tire. Even with same dimension, tires can be over 1'' different in width. Lowering doesn't matter...
Old Feb 15, 2011 | 10:30 PM
www.usarim.com's Avatar
Former Vendor of MBWorld
Mercedes Benz AMG
You should be fine in the rear with proper offset and you will be fine I have used hankook k110, pilot sport AS+ and both have worked fine with no issues
Old Mar 29, 2011 | 12:56 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
How about 245 fronts and 275 rears on "eurospec" springs? I am thinking these will rub (18 inch monos).
Old Mar 29, 2011 | 01:49 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I run 235 front and 265 rear with no rubbing but looking at how much clearance I have I doubt you could go much bigger without rubbing.
Old Mar 29, 2011 | 02:03 PM
pnsji's Avatar
2 55s
I also ran 255/35/18 on 18x9 wheel with H&R + Bilstein Sports. No rubbing.
Old Mar 29, 2011 | 03:59 PM
popey24's Avatar
I use 245/35 front and 285/30 rear, but you need to modify your fenders and rear bumper.
Final step might be 19x9 front with 245/30 or 255/30 and 19x11 rear with 305/25 or 315/25 but it could get a little difficult...
Old Mar 29, 2011 | 06:56 PM
"I use 245/35 front and 285/30 rear"
"Final step might be 19x9 front with 245/30 or 255/30 and 19x11 rear with 305/25 or 315/25"
Old Mar 30, 2011 | 05:15 AM
KJI3jflarryfe93's Avatar
503C43 now you begin to scare me with those dimensions.
it will be a slow heavy rotation mass to pull everytime you are going to squosh those Bavarian competitors @ the redlights!
ho ho hoe
Old Mar 30, 2011 | 09:32 AM
popey24's Avatar
For 305/315 tires on the rear, it is necessary to go down to minimum offset (of 15) allowed here in Germany and it will be still critical on the inside of the wheel. For the 285 tires I needed to use offset 25. For sure I need to redesign my fenders...
Another problem is that there are only a few ires available for those dimensions and if the tire is worn out, you don't know if still available.
Had the same problem with the Hankook K104 245/35-18 285/30-18. Once there was a front tire damaged and the K104 was no more available. So I combined with 2x V12Evo in front. Now Hankook doesn't offer the 285/30 anymore. The new V12 in that dimension is available for US market only (no certification for Europe). Other tires are often specified for Porsche or if the rear dimension is available the front dimension isn't or vice versa.
Old Mar 30, 2011 | 05:47 PM
Are you really losing that much traction that you need 285 rears?
Old Mar 30, 2011 | 10:17 PM
silence's Avatar
sounds like airplane
I've run some 275/30/19s (I think in the past)
Currently running 255/35/18 and very happy
Width won't help the traction as much as going to a slightly taller/softer tire on a smaller rim would.
