slight vibration while in P
1998 s320, 1995 e320 cabriolet, 1995 c36, 1988 230ce 5 speed, 2004 CL55 AMG
I noticed a slight vibration the other day while letting the car warm up but then was unnoticeable while in D at a red light. Is this a sign of motor mounts or trany mounts going bad or what? any thoughts?
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Yes you do...
Get a broad piece of wood that will displace the weight of the engine over the jack's head.
Not my post - but it is exactly what I did
Here you go - LINK
Credit goes to member 'myc43amg' for the post, again it's an easy DIY. I'd change the steering dampener and starter while you're there. I just replaced the water pump on my Tacoma, which entailed removing the timing belt - this job is much easier.
You'll need to buy a set of e-torx if you don't already have - Sears has the Lisle brand for use on a 3/8" ratchet
