w210 motor mounts
Old Apr 20, 2011 | 03:50 PM
pfleger81's Avatar
1998 s320, 1995 e320 cabriolet, 1995 c36, 1988 230ce 5 speed, 2004 CL55 AMG
w210 motor mounts
this may be a total newb question but does the year matter when choosing the w210 mounts for a 98 c43?
Old Apr 20, 2011 | 08:36 PM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Why would you use them?
The W202 mounts are relatively cheap - why would you use the W210 mounts, am I missing something?
Old Apr 20, 2011 | 11:36 PM
pfleger81's Avatar
I think I read somewhere on here that the w210 are better/more durable than the w202? Not sure where but is there any truth to this?
Old Apr 21, 2011 | 11:14 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
If I am not mistaken I believe this is in reference to the E55 mounts, not just any old W210 mounts as there is a 3.2 and 4.3 that goes in the W210 as well and I can't imagine the 3.2 or the 4.3 mounts are any stouter than the C43's...
Old Apr 21, 2011 | 11:44 PM
pfleger81's Avatar
Yup that rings a bell. So e55 mounts better than c43?
Old Apr 22, 2011 | 01:14 AM
I have heard that before but I do not know for sure...
Old Apr 22, 2011 | 01:35 PM
Jasssc's Avatar
1996 Mercedes C36 AMG
bushings from the w210 are better if i'm not mistaken, somebody correct me if i'm wrong, but aren't they solid while the w202's are hollow, or something along those lines?
Old Apr 22, 2011 | 04:33 PM
Motorsport3's Avatar
Dynocomped C43K, 08 X5
I think the w210 e class model shares same motor mounts. I dont know why its better than our mounts. I think they both use hydraulic fluid in the mounts. Prices are about the same as well.
Old Apr 22, 2011 | 06:08 PM
hoontastic's Avatar
99 c43 / 99 ml430
its the same engine with a different bore.. so likely the same mounts
Old Apr 22, 2011 | 11:14 PM
Saaboteur's Avatar
eclectic assortment of cars
I posted about this topic in the stickies '55' swap thread. There are different part numbers for the C43 vs the E55 engine mounts. Anecdotal evidence is that they are 'better' whatever that means. I intend to buy a pair of 55 spec mounts for my swap. I do hope that the external dimensions are the same.
Old Apr 22, 2011 | 11:38 PM
StapleGun's Avatar
Give us the 411
Let us know if they are...we'd all like to know
Old Apr 23, 2011 | 02:54 AM
I've already installed e55 lamfoerder motor mounts and to tell you the truth... I donno what make these w210 mounts better than c43's motor mounts. I mean I couldn't tell the difference Maybe they last longer with no fluid leak. Its not like urethane motor mounts that you can feel the difference right away. I wish someone makes urethane motormounts+tranny mounts for our cars... sigh....
Old Apr 23, 2011 | 06:09 AM
popey24's Avatar
C43 AMG 5.5 - 396.4HP
Simply don't use the hydraulic ones.
Old Apr 23, 2011 | 06:17 AM
KJI3jflarryfe93's Avatar
aren't they all hydraulic motor mounts?
what do you then recommend?
Lemfoerder is the best when it comes to aftermarket parts
Old Apr 24, 2011 | 10:10 AM
popey24's Avatar
There are hydraulic ones or metall/rubber available. I used the metal/rubber one.
Old Apr 24, 2011 | 12:17 PM
If I go to the stealership with an E55 AMG VIN # (chassi number) am I going to get hydraulic rubbers or metal/rubber motor mounts, these cars must have the best engine mounts installed from factory?
Maybe non AMG cars have hydraulic moron mounts?
Old Apr 24, 2011 | 10:15 PM
Where can I get those non hydraulic one?? stealer??
I really one them!! I may get some engine vibration but I rather have more solid feel.
