HID foglights....?
Old May 5, 2011 | 07:45 PM
justinwrock's Avatar
Ducati
HID foglights....?
Does anyone have HID foglights?
If so, can you post pictures of how they look, and your setup... I want to get yellow HIDs for my foglights.
Old May 5, 2011 | 08:32 PM
hoontastic's Avatar
99 c43 / 99 ml430
get a 3000k hid kit.. I swear by these guys. ALOT of fellow forum members on the w163 benzworld forums have installed this kit including myself. Previously on my ml430 I had osram nightbreakers which are some of the brightest halogen bulbs.. I am running 5000k 55w HID's for my lows and the lights are SO MUCH BETTER than halogens. Obviously for the fogs you will want to run 35w because of heat and limited space. These ddm tuning guys are actually the manufacturers and distributors so the pricing is really good.
Obviously there are lots of choices for HID kits.. I just have had a really good experience with DDM.
I will be retrofitting HID's into both the lows and fogs when i get a chance.
Old May 6, 2011 | 12:17 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Check out this thread:
https://mbworld.org/forums/c36-amg-c...og-lights.html
Old May 6, 2011 | 12:38 PM
bsmuwk's Avatar
Depends on the day
get the ddm kit justin.
i have those on my coupe.
Old May 6, 2011 | 02:06 PM
hoontastic's Avatar
99 c43 / 99 ml430
not to threadbash but one of my fogs has moisture.. Has anyone run into this and solved it without resorting to replacement?
Old May 6, 2011 | 02:14 PM
Ducati
Pop the rear cover off and let it evaporate.... Should be OK for summer.
Remove from car and inspect for seals/cracks for long term. You might have a bad seal where the glass meets the housing.
Old May 6, 2011 | 02:16 PM
Ducati
Hmmm, I have a spare housing and some spare projectors.... Thinking projector retrofit.
Old May 6, 2011 | 02:26 PM
hoontastic's Avatar
99 c43 / 99 ml430
well yeah but i assume its getting in there somehow.. so i didnt know if there was a known way to reseal it.
Old May 6, 2011 | 02:43 PM
Ducati
The seals on the lamps are a replaceable part. Most MB lights have rubber or foam seals that you can buy and replace. Handy when your taking lights apart to mod them. B) No need to bake them apart.
Here is some info for you:
The C43 lighting section on EPC does not list the fog lamp parts... Only the complete unit.
Fortuneatly, it does cross to a SLK230 fog lamp, which does have an exploded view of the lamp.
Old May 6, 2011 | 02:44 PM
hoontastic's Avatar
99 c43 / 99 ml430
awesome - you have to bake the lights on the ML.
Old May 6, 2011 | 04:42 PM
DRBC43AMG's Avatar
Neat solution. I dismantled mine, cleaned everything up, put some silicone grease on the rubber seal and put back together. Changed the lights to clear glass ones after.
Old May 6, 2011 | 05:52 PM
They are not "sealed" to begin with, there is a small breather hose on the back that is supposed to help prevent moisture.
You can have the back off my old fogs if you want, I never had a problem with moisture in my fogs so I would believe the seal is good...
Old May 6, 2011 | 10:16 PM
tri-star tech's Avatar
2004 CLK55
Here's how I did mine the other day
http://www.club202.com/forums/showth...-Light-Install
Old May 7, 2011 | 05:39 PM
Motorsport3's Avatar
Dynocomped C43K, 08 X5
So, what should I get with the hid kit?? there are 3 more options to choose from.
I have PIAA Yellow in my fog lights and they are not yellow enough for my taste
I never thought of using 3000k hid for that bright yellow flooding light!! I should get this asap!!
