Regarding the 4.3L V8...
Talk about epic overkill in answering my question! Well, at least that now finally puts my question to rest!
Aside from being lightweight, the intake manifold on normally aspirated M113 V8 has the longest intake runners in the industry. Under hood space was saved by casting the manifold so that the long intake passages spiral around to each cylinder. Internally, the intake manifold has eight valves built into it. These valves are closed below 3,700 RPM, directing the intake air across the long intake path. That's because when an intake stream follows the long route, pressure waves develop that result in an improvement in low and mid-range torque. Unfortunately, this long path becomes a detriment at higher RPMs. In the M113, above 3,700 RPM the valves open and the intake air follows a much shorter route. This shorter route dramatically increases high speed efficiency, resulting in a substantial increase in horsepower. These ECU controlled valves create an environment in which the engine can breathe at maximum efficiency throughout the rev range.
I LOVE THAT "KICK"!!!
THREAD JACK!!
Like hoontastic said:
(O)regon (A)MG (O)wners (C)lub
I have started a club for owners of AMG's that live in Oregon, currently we have 6 members including myself as well as 2 members pending. We are ALWAYS looking for more members so if you own an AMG and live in Oregon PM me and we can get you in.
I am currently working on starting the Washington chapter as I have had several forum members from Washington express interest in joining but unfortunately it is only for residents of Oregon. Then I got an idea, why not start a Washington chapter???
I am putting together our first meetup which will be in July. It will start with a meet up at a local coffee shop or breakfast spot then it will be on to the 35th annual historic races @ PIR. There will be vintage race cars on display and RACING!!! Not to mention a hot rod show as well as an autocross event. We will finish it all off with a 1.5 hour cruise on a route I have designated that has plenty of twisties as well as it's fair share of straight aways
If you live in Oregon or Washington and are interested in joining PM me
Jason
