When I hit my panic button my lights flash but not siren. I also do not hear a chirp when I lock/unlock. I think it may be disconnected or faulty. Also, I believe the owner before me had a aftermarket alarm system installed, due to 3 little led red lights that are in the instrument panel. These lights may be stock..idk. Anyways, where is the alarm siren located on the c43?
Here are screen shots from the WIS:
My "alarm" works the same way that you are describing. I believe it is due to the fact that I have the tow alarm but not the actual alarm with the motion sensor, are you sure you have the motion sensor?
Unless you have the full alarm I do not believe the alarm will sound unless your car is being towed.
your alarm will only go off if you open your trunk when the alarm is activated.
your 4 doors doesn't have any sensors if broken into.
your hood will not sound the alarm if broken into.
your car will sound the alarm if being towed away, lift car and the alarm is blasting.
these stuff above is what happens on my car with tow alarm
Sounds about right...Originally Posted by kowalski
your alarm will only go off if you open your trunk when the alarm is activated.your 4 doors doesn't have any sensors if broken into.
Quote:
I hope I äm right about my previous post!Originally Posted by 503C43 ////AMG
If not then my alarm is fuuked??
I'm wondering if any of you forum members who ONLY has the stock factory tow alarm, if you can test your cars and report if it's the same procedure as it is on my car???
Check all these parts:
# Sit inside the car and lock with remote. No sounding alarm when all 4 doors opens when alarm is activated?
# No sounding alarm when you pop the hood from inside cabin when alarm is activated?
# Does alarm set off when you unlock the trunk with metal blade key?
OR
If you pop the trunk pull out the pin it kills the trunk light, lock the car with your remote but keep the trunk open, then pull out the pin and then alarm starts blasting!
DRBC43AMG
close
- Join DateMar 2010
- LocationLand of mountains, cheese, chocolate and watches
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG + Ultima Can-Am sold)
Liked:323 Times in 268 Posts
All this is mumble jumble to me and too complicated
All I see are flashing red leds when the car is locked period
That's sufficient for me
That's sufficient for me Banned
all this jiberish is muy importante to know what works on your car and what doesn't work!Originally Posted by DRBC43AMG
That's sufficient for me you have the full setup diebstahlwarnanlage on your C43, I only have the abschleppschutz alarm, both versions might differ in different functions?
You maybe have burglar sensors on the 4 doors and the hood, which I might be missing, whooooo knows?
DRBC43AMG
close
- Join DateMar 2010
True, and I should look and find somewhere at home the list I have giving ALL the options included when they built my car
ExploreBanned
Quote:
you can also try these stuff on your car at home.Originally Posted by DRBC43AMG
# sit in the car and pop the trunk, does alarm go on?
# sit in the car, open the doors from inside, does alarm go on?
# sit in the car, alarm is activated, start making heavy metal noise with your keys, does your interior motion sensors go on and sound the alarm?
# unlock your trunk with the metal blade key, does alarm go on?
or
if you open the trunk, pull out the pin (trunklight off) keep the trunk open all the time, now lock the car with your remote, now pull the pin and the alarm is on blasting.
My towalarm starts blasting if the trunk is being molested or my car being towed away, nothing else.
