Base line dyno run for C43
#178
UPDATE:
I have received my headers AND have sourced the final piece to the puzzle, the Renntech air box. The box should be shipped out to me on Monday.
I am going to change my dyno plans and should be running the following:
1.) after Renntech air box has been installed
2.) after Kleemann headers and high flow cats have been installed
3.) after Eurocharged tune has been installed
Eurocharged will make a custom tune depending on the mods you have. Since the remote tuning process is kind of a hassle I figured I would get all of the mods installed and then tune once.
I will be setting up an appointment to get my headers installed ASAP.
#179
07 Daytona 675, 05 C55, 00 ML55
I think you should dyno with the headers and high flows first then put on the renntech box. Don't you get a few pulls when you setup a dyno? Do the first pull with the headers and cats, then pop on the renntech airbox which is easy. I can't wait to see what you finally put down after you ecu tune.
#180
1 Post
Carlsson CM60 EX:C36AMG'96
UPDATE:
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
#181
There's a special place in heaven for those that have your patience 503, just be prepared to leave the radio off for a while...once you take the gag out of her mouth you will only want to hear her sing! CAN'T WAIT!!! ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
#182
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Looking forward too
I hope to get my 43 out of hibernation and back on the road, but I may have to delay this (or else get the work done by my trusted tech, but then where is the fun of doing it yourself), as I my left hand needs surgery and that will keep it out of operations several weeks
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
#183
UPDATE:
My Renntech CF airbox should be sent out tomorrow and I should receive it in about 5 days.
I can't wait![Wootrock](https://mbworld.org/forums/images/smilies/wootrock.gif)
The only sad part is I am running out of mods
Not much left except an LSD, S/C or 55 swap
Most likely I will go with the 55 swap (and then maybe a S/C
) but I will do the LSD before that as not only is it cheaper but it will help put all that power from the new motor to the ground
I can't wait
#186
UPDATE:
Look what arrived today![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
![](http://i1213.photobucket.com/albums/cc470/Jayo503/renntechairbox001.jpg)
The bottom has been heat shielded![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
![](http://i1213.photobucket.com/albums/cc470/Jayo503/renntechairbox002.jpg)
It came with K&N air filters but I am thinking about replacing them with OEM filters due to the fact that apparently MAF's and K&N's don't mix well.
I will be installing this bad boy ASAP and then scheduling the dyno to capture the gains.
#188
I have seen from 6HP to 20 HP and Renntech claims 15-20HP. I know there have been some members on here who have done independent dynos and have come up with similar numbers. Hooleyboy dyno'd 10 RWHP gain. I am unsure if Renntechs numbers are at the crank or at the rear wheel.
here is a link to a thread about it:
https://mbworld.org/forums/c32-amg-c...dent-dyno.html
Either way, without a doubt it adds power
#191
00 C200 & 00 C55 & 06 SLK55
main point, ENJOY.........
ZAYED,,
#192
#193
2015.5 Volvo V60 Polestar
Dump the K&N's, and get a set of AFE Pro-Dry S's.
http://afepower.com/shop/details_new...3L&&brandID=59
Using them in my Renntech box on my CLK55 and my stock airbox in my ML55. Great filters and no oil to worry about.
#195
Going to do before and after with the airbox?
Yes dyno's will be performed with the box and I will check out those filters. Are there any HP gains with the AFE filters?
#196
Either way, without a doubt it adds power![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Cheers,
Paul
#198
Hi Paul,
OT perhaps, but I have just had a look and been through your "Turbo" site. OUTSTANDING engineering
That is some serious tuning and I guess you could go and work with AMG anytime
Great work ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
#199
UPDATE:
Just ordered 2 of the AFE pro dry S filters for my Renntech air box, they should be here in a week or so. I opened up the box and you could see some of the oil from the K&N's caked inside of the box. that's all I needed to see to push me towards dry filters.
I will not be installing the box until I get the new filters, I will clean up the inside and I am thinking about redoing the heat shielding on the bottom of the box while I am waiting for the new filters.
I will post pics of the inside of the Renntech box VS the inside of the stock box for comparison.
