tip-tronic in pre-2000 models
#202
00 C200 & 00 C55 & 06 SLK55
Yes, That’s the piece which hold to the denet plate and catch the guide bushing, now you need to get a cover & O-ring & washer,,
Ahh sorry, i didn’t give you the part #s to closed the linkage hole,,
1) cover: "140 270 08 05"
2) O-Ring: "022 997 87 48"
3) Washer: "N006902 007100"
4) Screw: "140 990 58 01"
ZAYED,,
#204
Great thats cleared that up if i get stuck will let you know
Zayed i have done exstensive research on the wiring i am really suprised that your mates car was just plug n play
The wiring loom in our car is really different from the current wiring harness only 3 wires are used the rest a new loom has to be made going to correct positions
#205
No my friend, i didn’t say plg & ply,, i just said my friends car is easier to work with, cause it has a latest version of wiring & TCU,
That’s which makes the things different,,
depend how luck we have....
ZAYED,,
ZAYED,,
#207
1995 C36 AMG, 1998 C43 AMG
Zayed for future reference, any chance you could get the build date of your car and your bud's so we might have some idea when they switched it and what ours have?
#208
need to find out closely about that......
#210
Zayed i have both shifters side by side they are both totally different. I dont understand how just by changing the housing from the old shifter will make it fit in the housing from the old shifter is totally different
#212
Do you pulled over your shifter(which is in the left side)...?, if so, do you have a plastic bracket under it...??, or just the one in the pic.....???
ZAYED,,
ZAYED,,
#216
I asked you that, cause i need to clarify important thing, there’re "2" different tunnel & insulation area under the shifter,,
One comes with an alloy bracket that holds the shifter, and the other comes with a plastic in the shifter it self, that depend of the car spec. & Vin #,
The "W202 & W208 & W210 & W170" between "aug1999 to fab2000" comes with a thin bigger hole alloy bracket that holds the shifter in it,,
cause MB expanded that tunnel hole to match the Tip. shifter after "apr2000",, some models got that bracket & some isn’t,,
Although it has like our shifter,,
That’s why i need to get my friends car to confirm if that bracket comes separately, or with a tunnel assembly.....
ZAYED,,
ZAYED,,
#217
If you can contact the shop you bought your shifter, and tell them to pictured the area under the shifter, you will see clearly if there’re a
bracket or not....
ZAYED,,
bracket or not....
ZAYED,,
#221
Have received all parts this morning. Ready to fit them on.
Zayed what shall i do strip the old shifter and put new shifter parts in? Is that what i need to do as i don't think they will fit it can you confirm this?
#222
I went to the dealer today,, unfortunately they said; the tunnel bracket in the late of the W202 NOT comes separately,, it comes complete assembly, and when i asked them about the part # of the bracket or at least the tunnel assembly, they said we don’t have it in our system,, we need to contact the Germany dealer...,,
And about the wiring diagram, they said; you should to purchasing the wiring diagram from our shop,, because we loving you, we will give it to you around ($10,700)..., don’t forget, that price reflects how much we loving you....
ZAYED,,
ZAYED,,
#225
That’s why i told you how lucky lucky my friend is,, any way; i Emailed one guy in Germany yesterday to give me the bracket #
or the tunnel assembly #,
And i called my friend today, he didn’t answer until now,, im waiting for both to answer me shortly, AS I HOPE.....
ZAYED,,
ZAYED,,
