Awful "scraping" sound when locking the car...
Old Dec 6, 2011 | 11:39 PM
JohnnyRock's Avatar
1998 C43 AMG
...is coming directly behind the fuel-filler door...WTF?!?!
Ever since I bought the car it's made this metal-on-metal "scraping" sound when locking the car with the remote. Anyone have an idea what the hell this is?
Even better, how do I fix it?!?!
Old Dec 7, 2011 | 12:17 AM
PJmak's Avatar
Its the lock on the gas tank lid, i have the same problem
Old Dec 7, 2011 | 01:57 AM
DRBC43AMG's Avatar
A bit of lubrication on and around the plunger may help
Old Dec 7, 2011 | 07:37 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Check the lid - it may be slightly bent in or out and causing your problem...
Old Dec 7, 2011 | 07:38 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
open the little fuel door and then lock the car, you will see a small air pump push out a metal rod. The rod is used to lock your fuel door so someone couldn't dump sugar in your tank.
I'm sure you are missing either the lubrication or gasket of some sort.
Old Nov 14, 2012 | 09:06 PM
JohnnyRock's Avatar
1998 C43 AMG
Just a quick update, this^^ was the cause of my problem. I tried some graphite lube at first, which didn't do isht. So I applied some spray-on lithium grease and it worked like a champ!
Old Nov 20, 2012 | 06:41 PM
koich's Avatar
1998 Black Opal C43
Good thread. I have the same problem. I knew it was the gas lid, but was too lazy to lube. Will do that tonight when I get home.
Old Nov 20, 2012 | 06:48 PM
Capn's Avatar
03' CL600
Definitely need to lube it... the fuel filler door.
Old Sep 29, 2014 | 08:45 PM
JA50N_FL's Avatar
Glad I found this post. I knew where the sound was coming from.. just not sure if it was safe to lube that plunger. I will lube it now.
Walking away and hitting the lock on remote, the car sounded like it was breaking wind.
Old Sep 30, 2014 | 09:33 AM
DRBC43AMG's Avatar
Sometimes a quick search finds suitable solutions to a host of small problems
