Im in a bind... need a spring compressor.
Old Dec 26, 2011 | 01:39 AM
Super B's Avatar
'97 c36
Since I had to take the truck down to my parents to deliver my nephews Christmas gift (old school mini bike kinda like trail 90) figured it was a good time to pull the lower control arms and use pops shop press to install the bushings. Like a dumb ***, I figured the spring compressor I had would have been good enough but after getting there and seeing how much compression is needed. Its just not safe and I dont trust it from hurting/killing property or person. Any body in the Portland OR area have a MB style compressor I could rent/borrow for a couple of days? beer? cash? ??
Old Dec 27, 2011 | 03:52 AM
DRBC43AMG's Avatar
The real thing (spring compressor) are expensive but the only safe way of doing the work. Looks like you are stuck with those contraptions...
Old Dec 27, 2011 | 06:14 AM
320 dreamer's Avatar
2003 porsche 996 turbo
http://www.ebay.com/itm/Mercedes-Ben...ht_2348wt_1348
not really that expensive i have this set and use it all the time
Old Dec 27, 2011 | 10:36 AM
DRBC43AMG's Avatar
Yes that's a real look alike. Made in China perhaps?
Old Dec 27, 2011 | 02:58 PM
Super B's Avatar
'97 c36
Thanks for the link 320.. I bought one just like that. I ended up backing out and putting the car back together till the compressor shows up. I also decided that since I was going to have to wait to get the compressor. I ordered the solid w208 bushings and just going to resell the brand new lemforder w202 bushings.. so If any one needs some hit me up. $50 bucks
Now that I'll soon have the tools, if your in the Portland area and playing with your springs. Beer talks..
EDIT- I forgot to say, don't EVER!! attempt to try to use the compressors in the picture. These compressors are for Struts with larger diameter springs.. when I lowered the control arm down, the spring bulged side ways and the compressor started sliding up and around the coil... damn scary good way to get seriously injured or killed.
Old Dec 27, 2011 | 06:21 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Why did you chose to go with the W208 bushings over the lemforder? You should go all out and get the K-MAC kit so you can lower your ride and keep the camber in spec.
The majority of my suspension components are Meyle HD, Febi, and Lemforder. Lemforder is a GOOD brand.
Old Dec 27, 2011 | 07:22 PM
Super B's Avatar
'97 c36
Yeah I'll probably end up with the k-Mac kit when/if i get some lowering springs. I just want to make sure I'm 100% happy with the c36 before starting mods. As far as the bushings the w208 bushings are lemforder as well only they are solid rubber on the w208 unlike the w202's factory bushings. This is my Daily driver so got to keep it somewhat civilized.. Other wise id probably just go full poly..
Old Dec 27, 2011 | 07:39 PM
well mine are baum tools and i dont know were there made at. what i do know is i have used them on 3 different cars and on mine 4 times without a singe issue. so thats good enough for me
Old Dec 27, 2011 | 08:17 PM
isstay's Avatar
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
Much cheaper one:
http://www.sears.com/shc/s/p_10153_1...2&blockType=G2
Old Dec 27, 2011 | 08:28 PM
Originally Posted by isstay
that wont work on the m/b
Old Dec 28, 2011 | 03:56 AM
raymond g-'s Avatar
99 E320
if you're ever in the Seattle area, give me a shout. have pancake style
compressors. also experienced in safely lowering rear control arms with
and without the compressor on the 210s...which, I believe, the 202
shares in design.
sometimes even the pancake design may not work if the springs have
tightly wound coils so one needs to get a little creative
Old Jan 9, 2012 | 03:14 AM
Super B's Avatar
'97 c36
Oh snap look at what I got!
Worked like a kid in china. GREAT.
Got the arms out and going to press the bushings tomorrow. Feel good about getting this taken care of. You could feel the car was loose in the corners. Under close inspection one of the bushings was on its way to tearing clear though.
Old Jan 9, 2012 | 08:25 AM
DRBC43AMG's Avatar
Nice to see the correct tools being used Looks like you also have the knuckle splitter too Easy work when you are equipped with the right stuff.
Old Jan 9, 2012 | 01:16 PM
Super B's Avatar
'97 c36
Hey DRB Im glad you chimed in. Hey do you know if there is a proper position the w208 bushings need to be pressed into the control arms?
on the w202 bushings its kinda obvious, but on these solid 208's does anything go?
Old Jan 9, 2012 | 05:04 PM
PM MarcusF I am betting he would know as he know EVERYTHING MB related
Old Jan 9, 2012 | 05:53 PM
Super B's Avatar
'97 c36
Damn Jason good idea.. It worked out I'n the end though. It does matter.. The hole I'n the bushing is offset for camber. After a cup of coffee and measuring the tight side of the bushing goes inboard towards the engine.
Old Jan 25, 2012 | 11:33 AM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
Would you guys happen to know of a proper one to use for a W203 (C55 AMG)?
I found the following: http://www.ebay.com/itm/Mercedes-BMW...item19cbc828e9
Thoughts?
Old Jan 26, 2012 | 11:46 AM
JohnnyRock's Avatar
1998 C43 AMG
Super B, I need to do a front end refresh on my '98 C43 soon. Any chance you'd be willing to rent that compressor out? I'd pay shipping, leave a deposit, etc.?
I'm sure my control arm bushings could use some attention by now.
Old Jan 27, 2012 | 04:37 PM
Super B's Avatar
'97 c36
Shoot me a pm.. Where you live?
