Helllp!!!! Please
it just wouldnt start i opend the hood all look ok no vacum leaks nothing
, i unpluged battery for 10 mins plug it back and car started right up, i have no clue what happend no check engine light came on, i drove it home
turned it off , turned it back on and it turned on, but now i dont know if this is going to happen again
, any ideas on what the issue might be, thanks in advance.
ZAYED,,
Have a good check of your battery condition (water level, etc.) as it gets kind of forgotten in the bottom of the rear trunk
Battery is 5 weeks old, only thing i can think is maybe the cps because it cranked strong but didndt start, i felt like it kinda of was trying to start and it would at times but would just die, so not battery , defenatly had gas, so cps is my only suspect for now. thing is if it is the cps would it just die on me as if if ran out of gas?
diagnose the car, it takes around 15-20 minutes only,, then everything well be clear to you without guess & headaches........
ZAYED,,
that’s also effect to the Engine performance,, sometimes Engine lights comes on & sometimes not,, anyway its very important to change the
CPS after a while, to take a good optimise..........
ZAYED,,
1) #: "003 153 27 28 or 28 28"
2) #: "003 153 95 28 or 96 28"
*it depends of the CPS connector plug in your car,, one comes with "1" pin, which uses "003 153 27 28 or 28 28", and the other with "2" pins
which uses "003 153 95 28 or 96 28", you need to pull the connector plug & see how many pins you have.........
ZAYED,,
ZAYED,,
ok thanks bud.
ZAYED,,
DONE
