How often does these arms go bad?
Old May 11, 2012 | 03:08 PM
KJI3jflarryfe93's Avatar
Question How often does these arms go bad?
do I buy single bushing and press it out or is it better to buy complete rear axle bottom arms when they go bad?
I guess a lazy mechanic on his job at the shop would say it's better to swap complete arm.
http://www.autohausaz.com/search/ima...2023500206.jpg
what should I do, swap bushings or buy complete new arms
Old May 11, 2012 | 05:31 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I guess a lazy mans job at the shop would say it's better to swap complete arm.
I just swapped them, call me lazy I guess
Old May 11, 2012 | 07:04 PM
it's been a looooooooooong teim Jason.
i guess i can call you lazy then??
did you notice any improvement of the swap?
Old May 11, 2012 | 10:10 PM
Hard to say, remember I replaced pretty much my entire suspension so saying which part made an improvement is pretty much impossible.
Old May 12, 2012 | 06:56 AM
with all new parts you did notice your car having better performance handling around corners and in high speed straightline driving or was it like a placebo effect?
w202 chassi is a bit sensitive to wind
Old May 12, 2012 | 02:32 PM
Handling improved exponentially! It was like night and day. As far as W202 being sensitive to wind, I have never had that problem.
Old May 12, 2012 | 03:11 PM
i had this prob with wrong alignment when i did the swap from 17 to 18 inch rims, never did an alignment, when i drove on a bridge and it was blowing hard my car wasn't having any stability.
now i guess it's a different story with new rubbers and a fresh 4 wheel align which i did last year.
Old May 12, 2012 | 10:55 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Those bushes almost never wear out. The rose joint on the other end of the arm (actually in the wheel carrier) does wear out and is an easy replacement and the torque arm wears out too (just replace the whole arm).
They are still an easy bush to replace, replacing the arm isn't expensive and is a good option for a home mechanic rather then pressing the bush out.
Old May 13, 2012 | 07:28 AM
is this bushing named as the rose joint?
located on rear axle wheelhub (wheel carrier)?
http://www.autohausaz.com/search/ima...2203520227.jpg
Is this arm called the tourqe arm?
how often does this rear diff mount wear out?
is it an expensive bushing at the dealer
http://www.autohausaz.com/search/ima...23511142MY.jpg
This bushing is it the same one on the end of the arm as seen on the link below?
http://www.autohausaz.com/search/ima...2023520065.jpg
Old May 13, 2012 | 01:43 PM
The rose joint is not a bushing. post #14 in this thread you started has pics of a rose joint:
http://forumss.mbworld.org/forums/c3...toe-links.html
Old May 13, 2012 | 01:49 PM
i checked the link.
only bushing i see is NO 8
what number does the rose joint have in the linked picture, what does it look like
Old May 13, 2012 | 03:13 PM
i checked the link.
Open your eyes Denis See how bushing number 8 has a line going to it showing where it installs. The line leads up to the rose joint, this is where bushing #8 installs on the rose joint.
Old May 13, 2012 | 03:20 PM
the rosejoint is no 5.
this part is never replaced, right???
i want to change all bushings on rear axle to cope with my new stuff on front axle.
i'm getting old, need goggles, 4 eyes
Old May 13, 2012 | 07:47 PM
This is the rose joint
Name:  ScreenHunter_01 May. 13 16.45.gif
I believe I changed out the entire arm due to the cost of the bushing and getting it pressed (or buying a press) was around the same $$$ if not more expensive than buying the entire arm new and installing it.
Old May 14, 2012 | 07:20 AM
Attachment 235479
you didn't buy new rosejoints?
i guess they are very expensive?
i might go for new complete arms i linked in the first thread and not having to hassle with pressing tools.
remove and replace with new parts goes faster.
