anyone try monroe struts from jcwhitney?
Old May 30, 2012 | 07:06 PM
illmaticnyc's Avatar
1999 C43 AMG
just an inquiry..they say theyre custom fit for this car. anyone attempt or any thou ghts?
oe spectrum?
http://www.jcwhitney.com/monroe-oesp...19205y1999g2j1
what about meyle struts?
Old May 30, 2012 | 07:19 PM
JohnnyRock's Avatar
1998 C43 AMG
Just a personal opinion, but JC Whitney parts (generally) belong on Buick's. Not AMG-appropriate equipment, if you ask me. Yes, it's a 'euro' thing.
Meyle makes very high-quality OEM replacement parts.
Old May 30, 2012 | 07:26 PM
1999 C43 AMG
any idea how the meyle struts are though? comparable to oem ? i dont want to mess with bilsteins not being the correct ones. too much going back and forth as to what is right between the HDs or the sports. i dont want to change the springs out either
Old May 30, 2012 | 07:57 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
the choice between sports or HD's is simple:
Lowering your car = sports
Not lowering your car = HD's
As far as Meyle, I have Meyle parts on my car but they are all Meyle HD.
This is a snipet off of their website:
In 2002 the MEYLE brand debuted with the first optimised vehicle spare parts under the name MEYLE HD parts. The parts which are clearly superior to original equipment components thanks to technical improvements raise the global profile of Wulf Gaertner Autoparts AG and are the flagship products of the MEYLE brand.
Old May 30, 2012 | 09:33 PM
JohnnyRock's Avatar
1998 C43 AMG
What 503C43 said !
You can't go wrong with the Bilsteins. Firm, yet compliant ride quality. Stick with the HD's for stock springs. Tirerack.com has a great price on Bilsteins.
Old May 31, 2012 | 03:38 PM
1999 C43 AMG
What 503C43 said !
i read on this forum that the bilsteins are the closest to oem stock but quite exactly? is that true? meaning that they arent the original shocks are they?
thanks!
Old May 31, 2012 | 05:07 PM
JohnnyRock's Avatar
1998 C43 AMG
thanks!
I can't say for sure, nor should it matter (in my humble opinion). The Bilsteins will work just fine and come with a lifetime warranty (I believe).
Old May 31, 2012 | 10:38 PM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
thanks!
Stock shocks on the C43 are Bilsteins, they're just supposedly "custom valved for AMGs"
Old Jun 1, 2012 | 02:32 PM
DRBC43AMG's Avatar
+1
Old Jun 1, 2012 | 03:32 PM
1999 C43 AMG
great info!!! now this custom valving...how much of a diff does it make? whats diff?
thanks again!
Old Jun 1, 2012 | 03:56 PM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
What is your end goal? Stock replacement? If you want the exact stock shock, go to the dealer and buy one. Otherwise, the Bilstein HD is a close replacement while the Sport is valved a little more aggressively. Please do not put anything from JC Whitney on your Benz.
Old Jun 1, 2012 | 04:09 PM
1999 C43 AMG
will not jc whitney bad!
however can i use the sports with my stock springs? or must i have it lowered?!
Old Jun 1, 2012 | 05:34 PM
nd4spd13's Avatar
It's been said many times before:
lowered=sports
stock springs=HDs or OEM AMG parts ($$$)
Old Jun 1, 2012 | 08:41 PM
ECTurboGSX's Avatar
You can run Sports with stock springs. It will be more aggressively damped than stock. You don't have to lower to run sports, but if you do lower, Sports are better than HD's.
Old Jun 1, 2012 | 09:01 PM
nd4spd13's Avatar
Running sports on stock springs will add extra stress into the suspension system. The Sport shocks are physically shorter than the stock shocks, so installing them with stock springs will either cause constant stress from the shorter shock compressing the spring, or the shock will be over extended from the longer spring.
Old Jun 2, 2012 | 10:49 PM
ECTurboGSX's Avatar
Are you aware of any Bilstein site that says that? Bilstein would have to disclose that if that were the case.
Old Jun 2, 2012 | 11:13 PM
nd4spd13's Avatar
I am not. And I definitely am not sure about the stresses it would add, but I do know for a fact that they are shorter, and would therefore cause some sort of added annoyance I'd imagine
Old Jun 4, 2012 | 05:01 PM
1999 C43 AMG
the mercedes benz parts catalog actually do have bilstein sports available for purchase. i wonder why? are they intended with different springs? you can order bilstein HD or sports FROM mercedes. why do you think?
Old Jun 4, 2012 | 06:01 PM
JohnnyRock's Avatar
1998 C43 AMG
You ask too many questions. The tried and true formula (as stated previously) is:
stock spring or equivalent ride height = Bilstein HD
lowered spring = Bilstein Sport
End of story.
Old Jun 5, 2012 | 11:42 AM
1999 C43 AMG
End of story.
point is that there seems to be some differences in what is to be properly used. some say its good. some say its no good. and this is a forum. questions ARE supposed to be asked!
Old Jun 7, 2012 | 12:19 PM
trustz's Avatar
2010 W204, 2014 W212, 2015 W222, 07 SAAB 9-3, 2016 AMG GTS
I found here is cheaper:
http://www.ebay.com/itm/120838899280...witem=&vxp=mtr
If you do get it, please post the result.
Old Jun 7, 2012 | 01:00 PM
mkoons's Avatar
1999 C43
End of story.
Amen. You can buy Bilsteins for less than Monroe's which I would not put on our cars to begin with.
