any issues w valve cover gasket at 135k?
Old Jun 11, 2012 | 01:41 AM
AwalBenz's Avatar
2013 G550, 09 Audi R8, 01 E55 AMG
I think my oil leak is coming from the valve cover gasket on my c43....its a pretty big leak...is this common? any diys?
Old Jun 11, 2012 | 02:53 AM
DRBC43AMG's Avatar
I did a search on this forum and found a DIY for valve covers and other things Not a c43 but similar engine except S/C. Valve covers are the same. It is a simple job but takes some time and you need to be very clean and installation needs for torque wrench and specs.
https://mbworld.org/forums/w211-amg/...lug-wires.html
Try a Google: w202 DIY
You may find some more info too
Old Jun 11, 2012 | 11:52 AM
Nachtsturm's Avatar
2015.5 Volvo V60 Polestar
Very common. My valve covers were leaking on my 05. It is a very simple job, but I had speeddriven take care of it.
Old Jun 11, 2012 | 12:43 PM
LawRens's Avatar
43
Do you have an ever growing pool of sludge piling up on the undercarriage cover? It can get pretty nasty
Old Jun 11, 2012 | 04:20 PM
DRBC43AMG's Avatar
Sure does accumulate and needs some serious cleaning when I get back home
Old Jun 11, 2012 | 04:35 PM
99CEEFOURTHREE's Avatar
99 c43,90 mustang gt supercharged convertible,07 acura tl type s, Hummer H3t pickup
Yes mine started to leak on pass. side at 135k so I just replaced both sides.Simple job.
Old Jun 11, 2012 | 05:40 PM
AwalBenz's Avatar
yes actually there is a mess of sludge on my undercover...also all over the oil pan and surrounding parts...
Old Jun 13, 2012 | 08:31 PM
koich's Avatar
1998 Black Opal C43
Great timing. I think I need to replace my gaskets too. Thanks for the info!
Old Jun 13, 2012 | 09:06 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Mine were leaking a tiny bit the dealership resealed them while I was having a "B" service completed and I haven't had a problem since
Old Jun 14, 2012 | 06:19 AM
KJI3jflarryfe93's Avatar
if you drive your car for short trips and your engine never gets correct working temperature, oil sludge will eventually built up in the engine.
Have a long loop run everytime you drive your car b4 you turn it off getting to work.
This means you have to leave home earlier to enjoy the loop.
I drive my car for approx 20 Km before I turn it off first time during the day.
I hope I don't get any sludge with this driving.
SAAB cars had lots of problems with oil sludge, SAAB autoshops had to change many engines on extended warranties
Old Jun 14, 2012 | 07:41 AM
DRBC43AMG's Avatar
Heya Denis, I think the replies concerning sludge was not a worry of sludge build up IN the engine, but muck deposited due to oil leaks under the engine on the sump guard plastic tray
Old Jun 14, 2012 | 09:32 AM
what are you saying you call me a lush?
Old Jun 14, 2012 | 03:35 PM
DRBC43AMG's Avatar
Err, what's a lush
I guess it must be funny...
Old Jun 14, 2012 | 03:53 PM
Err, what's a lush
being drunk.
as I didn't know what I was writing.
Old Jun 14, 2012 | 06:21 PM
koich's Avatar
1998 Black Opal C43
Where does everyone source their gaskets? From the dealer or is an ebay product ok? Looks like there's a company called Victor Reinz that makes them too?
Old Jun 15, 2012 | 02:39 AM
DRBC43AMG's Avatar
MB OE only for me!
Old Jun 15, 2012 | 11:11 AM
AwalBenz's Avatar
sorry guys not familiar with these engines much...so it seems the oil is coming more from the drivers side than passengers side. could valve cover gasket still be the issue? or do you think maybe timing cover seal? how would i know exactly? I'm going to degrease the engine, change the oil since i need one anyways and then see where its coming from after its dry?
Old Jun 15, 2012 | 01:03 PM
MarcusF's Avatar
2002 CLK430
The C43 has a V8. It has two valve cover gaskets - one on the passenger side and one on the driver's side. Either side, or both may be leaking. It could also be leaking from the oil cooler, which is common. In any case, you will have to visually inspect the engine to find the source of the oil leak.
