Need urgent help, please!
Old Jul 5, 2012 | 01:25 PM
KJI3jflarryfe93's Avatar
Tried the search function with different searchwords, don't know how to find an old thread.
It's about the climate control codes and I mean all codes that can be red scrolling the up n down arrow pushbuttons.
I think it's approx 100 different codes showing different stuff.
Can't find this important thread, it was a few years ago I red it on w202 AMG section.
Can someone help me finding it.
Many thanx
Old Jul 5, 2012 | 01:44 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Here you go:
http://www.benzworld.org/forums/w202...2-digital.html
http://lmgtfy.com/?q=W202+climate+control+codes
Old Jul 5, 2012 | 01:54 PM
Thankx Jason.
My problem is I need to know how to switch from Fahrenheit to Celsius reading, in which order it comes among all codes?
Can this be manually changed without involving STAR?
Don't wanna buy a used climate control unit if I can't switch from F to C?
On MBworld w202 section there was a thread about all codes a few years ago, can't find that thread.
Old Jul 5, 2012 | 02:32 PM
Originally Posted by kowalski
Thankx Jason.
Here is a thread that is more indepth on the DTC from the climate control unit:
http://www.club202.com/forums/showth...gineering-Code
From what I can tell you can't change any settings in the DTC menu, just read codes. I did however run across a thread where someone from England bought a climate control unit from the US and when he plugged it in it automatically switched from F° to C°. The climate control temperature display is based off of your outside temperature display. If the outside temperature displays C° then it should switch the climate control unit to C° as well.
I can't confirm this is how it works but it makes sense
Old Jul 5, 2012 | 03:17 PM
thanks for your reply jason.
the bottom reply from you about celsius display vs F display didn't made any sense to me.
My outside temperature sensor reads in C that one is connected to my cluster.
The other sensor for ACC if it reads in C and I get a headunit reading in F you say it will automatically switch to Celsius?
UK don't they use Fahrenheit for temp, I guess only their speedos reads in miles?
Old Jul 5, 2012 | 08:32 PM
Let me see if I can explain it better:
Currently your outside temperature display (the one in the cluster) reads in C°. The same programming that tells your outside temperature gauge to read in C° is the same programming that tells your climate control to read in C°. When you plug in the climate control it should check which setting the outside temperature gauge is set to and switch to whatever your outside temperature gauge reads, either F° or C°.
again this is something I read on another thread a while back, the guy even posted a video of it switching from F° to C° as soon as he plugged it in.
Old Jul 5, 2012 | 10:08 PM
dls55amg's Avatar
2003s55amg
many thanx to all that post info on the c43 amg ,recently i became the owner of a 98c43,took it over from my step son,which he neglected ,to many issues to list all at this time,due to the recent heat wave i recharged a/c,i noticed the condensor do not come on at all,never had an engine overheating until i recharged a/c this evening,does anyone know about the cond fans,do the help cool engine ? or a/c system only?slightly frustrated,the car needs many repairs but i do like it
Old Jul 6, 2012 | 03:11 AM
awesome dude, much oblige
getting a headunit from US of A shouldn't be a problem then.
great
