#1 Spring pads (front) + Vogtland springs = Rub?
I think the rear will be low enough, so I was planning on keeping the factory size pads back there. But, I was thinking of going lower in the front by using #1 (5mm) pads. Would I have any problems with this setup? Or should I just keep all my original pads when lowering it with the Vogtlands?
Thanks in advance for the help.
I am running Vogtland springs with the largest spring pads (#5 in front and #4 in rear) with no rubbing. Pretty sure if I was on a #1 in front I would rub over bumps.
Look at my sig pic, I am low but not slammed
I am unsure if the W201 spring pads are a different size than the W210 spring pads.
Cheers
Cheers
Cheers
Cheers
