Need help buying new tires
Old Jul 10, 2012 | 09:29 PM
bagelsjustbagel's Avatar
In search of W222
hey guys,
For some reason no matter what, I always seem to buy tires every year :/ This time my tires lasted 20kmiles (bfgoodrich all seasons), the time before that my KDW's only lasted about 16kmiles.
I am properly aligned (as much as possible- and the treadwear is even), but I keep getting crap use out of my tires- sure I turn agressively, but usually only on on/off ramps.
Either way I need new tires that will hopefully be quiet, smooth, and last me a long time!
18" Rims 245 of 255 rear, and 225 front. I believe sidewall is 45 or 40?
-Adam
Old Jul 10, 2012 | 10:04 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Originally Posted by bagelsjustbagel
hey guys,
-Adam
I would imagine your tire sizes would be 18/225/45 and 18/255/40 but I could be wrong
I am at 19,000 miles on my Toyo proxes 4 UHP all seasons and will be purchasing some new ones SOON. I have never done a burn out or brake stand but I am definitely guilty of power sliding corners.
Your tire wear seems to be normal to me
Old Jul 11, 2012 | 03:35 AM
svt ricco's Avatar
1999 C43 AMG
What's the exact size you need? I might be able to hook you up
Old Jul 11, 2012 | 03:46 AM
tc1728's Avatar
I got a set of 225/40/18's and 235/40/18's sitting in the garage right now if you are interested, over 80% life left. PM me if you are interested, I'll hook you up. TC
Old Jul 11, 2012 | 04:42 AM
Todd_Nash's Avatar
Chevrolet beat and Maruti swift desire
I feel your tire wear is ok, not so bad as you think. You can check out in Tire World.com. they will provide you the good tires and even tips for maintaining its life
Old Jul 11, 2012 | 07:53 AM
w202mylove's Avatar
Carlsson CM60 EX:C36AMG'96
normall wear, I would suggest Goodyear Eagle F1 Asymmetric 2 they last pretty long aren't to loud. personally I go with Pirelli p zero they last less and are a bit louder but got the best grip of them all.
Old Jul 11, 2012 | 08:13 AM
Kenneteriom's Avatar
There are various good manufacturers of tyres on whom you can believe on like
1. Goodyear
2. Michelin
3. Pirelli
4. Bridgestone
5. BF Goodrich
Wise food storage Discount Code
6. Nitto
7. Yoko- Hama
8. Kelly- Springfield
9. Continental
10.Dunlop
Old Jul 11, 2012 | 12:09 PM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
Here is a recent thread on tires:
https://mbworld.org/forums/c36-amg-c...es-anyone.html
If you're running 18's, you should probably be running 225/40/18 on the front and 245 or 255/35/18 on the rear. If tread wear and noise are your primary concerns, you'll want to stay away from Max and Extreme performance summer tires. Maybe look at a UHP or Summer Touring tire. Do you see a lot of below freezing weather in NorCal? If so, you may want to look at an all season. Just understand that you that you tend to give up performance for comfort and longevity unless you get into the more expensive tires that can win some of that back. One of the recent Car and Driver issues has a tire comparo and would be worth picking up.
Also, go to Tire Rack and read the customer reviews. They tend to be as unbiased as you can get. Good luck.
Old Jul 11, 2012 | 12:29 PM
In search of W222
Thanks for all the help guys! I've contacted the two people thus far willing to try and help me and we'll see where it goes from there.
Does anyone think that I may have problems running a 235 on the rear where a 245 or 255 should be?
-Adam
Old Jul 11, 2012 | 01:34 PM
Nachtsturm's Avatar
2015.5 Volvo V60 Polestar
I can't recommend Continental DW or DWS series enough. I run them on all of my cars except the ML. Only because they don't make a 285/50/18 haha.
Old Jul 11, 2012 | 02:57 PM
ECTurboGSX's Avatar
The only issue you might have is your cruise control not working properly. I ran a 245/45 on my rear as compared to a 245/40 and that was enough to make my cruise control not work at anything over 40 mph. I don't know how far you can deviate before you start seeing issues though.
Old Jul 11, 2012 | 03:29 PM
In search of W222
Hmmm did it immediate cut out everytime you went to engage it? beause I'm on 245/45 now and thats what it does.... I've been trying to trouble shoot it too!
Old Jul 11, 2012 | 04:03 PM
ECTurboGSX's Avatar
Yeah, it will simply not engage at anything over 40 mph. You can feel it try but not catch. If you are still running a 225/45 front tire, then the wheel speed sensors see different speeds than they expected between the front and rear and won't allow the cruise to engage.
Old Jul 11, 2012 | 05:06 PM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
-Adam
You should be okay running these. The width of the tire doesn't effect the cruise control as long as you have the same diameter (wheel plus tire). Get whatever width you want, just as long as you're running either xxx/35/18 or xxx/40/17. I think a 235 will provide a little bit of a stretched look on a 9" or 9.5" wheel
Old Jul 11, 2012 | 06:31 PM
ECTurboGSX's Avatar
That's not true. The outer diameter of a tire is a function of all three numbers in a tire size. Change any of the three and it impacts the outer diameter. The first number is the section width of the tire, or the theoretical width of the treaded section. The second number is the aspect ratio of the tire, which relates the side wall height as a function of the section width. The final number is the wheel diameter or the inner diameter of the tire.
Therefore, the outer rolling diameter of a 245/40/17 and 235/40/17 is different. Will it be enough to make the cruise control not function? No, I doubt it. The difference in OD should only be about 4 mm or around 0.15 inches. (40% of the 10 mm difference in width)
Old Jul 12, 2012 | 01:38 PM
In search of W222
tc1728 I pm'd you! I've got staples showing I'd be willing to buy tonight!
