Activated Charcoal Filter
with new one.....??
ZAYED,,
, i was right & pulled the trigger and replaced the Charcoal filter,, no any idle missed, power is incredible, happy with waking the beast again from that longy longy sick,, i didn’t find the
Charcoal filter for W202,, the stealership said its not available & needs 20-25 days to arrived,, for that i put a new one from W203........"
"ZAYED,,
"ZAYED,,
*when this filter damaged or blocked, it well locked-up much of air in the fuel tank, that well blocked the Regeneration valve either,, the air must to
burned in Intake Manifold through the Regeneration valve,, imagine how much air well suffocates the tank if you have blocked "Charcoal filter &
Regeneration valve", that well definitely effect the power,, also if you got the U.S version, it well effect more,, cause the U.S version is soo strict with
an environment low , for that the Charcoal filter comes with a shut-off valve, i recommended to check them out.......
ZAYED,,
ZAYED,,
http://w202cabindustfilter.homestead.com/
ZAYED,,
never changed this canister!
at how many KM's should it be changed?
at service mechanic doesn't check this part or does he?
to axxes this part is it to remove the inner lining cover on right side fender?
like exactly the theory of the air inside the cooling system & the brake system.....!!
!!ZAYED,,
when should this canister be emptied?
isn't there any health check ups for this part at service?
the powder dust seen in pics above should clogg the canister sometime?
I've seen canisters last the life of the vehicle and I seen others that fail
If the charcoal get wet it cloggs, most common way to get it wet is to flood the car or over fill the fuel.
i have done this b4 i was going to store my car for winter.
full tank of gas keeps moisture away.
maybe it was a bad thing doing this?
well I learn something new everyday.
thanks
Attachment 252918
2) U.S version comes with an Accumulator control
Attachment 252917
*Important to confirm which one or shape you have....??
ZAYED,,
Looks roundish and is right next to the hole where you fill up for gas.
Is this the right part? Part number on the front says a2024701289
https://www.dropbox.com/s/fihk5a8y3o...%2053%20PM.jpg
