SLK55 Oil Cooler Installed
damaged or seals goes bad, it well mixing oil with water,, i don’t want to think about risky nightmares,, in the summer the temperature sometimes
reachs "51C".......
ZAYED,,
, Those parts are new(see attach),,
No need any mods to put that cooler, it sets Exactly like the stock one, just need to cut the rubber hoses(that joint to the pipes), with little bit
twisting those pipes, it well fit perfectly,, and customizing bracket for the cooler(behind the bumper),, i didn’t comparing between them yet,
i well see & let you know.....
ZAYED,,
1) SLK55 oil filter #: "000 180 28 09"
2) Other M112s & M113s including AMGs oil filter #: "000 180 26 09"
3) pics. together
*noticed that the SLK55 oil filter got only 4 o-rings, and shorter than the one from all M112s & M113s, [don’t know the reason]...!?!?
ZAYED,,
Thank GOD, set perfectly.....
Attachment 244814Attachment 244815Attachment 244816
ZAYED,,
are you using Magnecore KV85 sparkplug wires?
are you happy with them?
did they ever pop off from the plugs or ignition coils?
have you noticed any improvements from Magnecore wires vs stock MB wires?
The difference between stock and these, it is difficult to say and remain objective minded, but they certainly look better with a bit of red color...
Also, if you need to pull a plug it is easier as you don't need to use the 17mm open spanner method to remove the cap
all kinds of feedback from many peepol is necessary before purchase.
Mag wires handles a lot of heat and possibly cheaper to buy than factory wires.
other than that I don't know if they are an improvement vs factory wires?
ZAYED,,
Feedback is soo important, specially with aftermarket wires,,
i have a bad experts with an Evosport wires, i put some pics. here:
https://mbworld.org/forums/c36-amg-c...-set-need.html
that’s why i been careful before purchased Mag wires,,
don’t worry; Mag wires are great wires, you can go with them confidently.....
ZAYED,,
that's why should to get the cooler core to put the External line in it..!
[see attached]
Attachment 326497
Attachment 326498
Attachment 326499
ZAYED,,
Tell me the last thing.. about the cooling in and out... how did you close these two? Or do you connect these two simply with a hose?
Is this for the coolant of the OEM oil cooler? What I have to do with these two ports?
