chip for c43
Enough said?
This means from 0 to 60 hp and from 0 to 30 ft/lbs torque, if you get 0 HP or 0 TQ that means you got what they claimed.
This "Chip" plugs into the IAT. Well, it works, it fools the ECU telling it the air intake is cold and the ECU injects more fuel than normal. This is obtained through a mere resistance. Nothing more.
OldBeaver
Posted from Mbworld.org App for Android
So far I made only one mod, using a small resistor: modified the starting temp of the auxiliary fans (the ones in front of radiator). They used to start at about 115 degrees centigrades. To avoid excessive heating of the engine, I set them to start at about 95 degrees.
Engine gets hot in high traffic jams in tunnels in Santiago.
It is not my idea. But I can tell you it works perfect.
Until soon.
OldBeaver
Fools the ECU through the ITA causes an interruption to the back MASS signal, this kind of chips can be used to the old version of the carburetor or LHF/MHF/KE system,, its risky to use the chip to the ME or HME like our system, cause our ECU has a signal reads the results of the MSG ignition through the ITA stored to the ECU data,,
Don’t go with that kinds of CRAP chips,, tune your car in proper way,,
Example:- https://mbworld.org/forums/c36-amg-c...o-run-c43.html
ZAYED,,
