changed my ignition to run on 93 gas
Old Jan 8, 2013 | 07:55 PM
99C43n843's Avatar
1999 C43 AMG
so I figured id share this with everyone. I had read on a way earlier thread about someone getting there fuel setting set from default to 93 octane fuel. so today we were slow and I pulled my car in and hooked it up to the sds (ran short test while I was there and good to say all checks..which is what you want to see). went into the M.E control unit and went into control unit adaptations. went to ignition and found the settings of the fuel octance. all of our cars are programmed on the "default" setting for "countries with poor fuel" there were four settings to pick from...default, 93, 91, 89. I set mine to 93 of course. appreantly the timing is retarded on other settings to compensate for poorer fuel so that the knock sensors wont trigger falsely. so im not sure if changing it to 93 will give any real advantages but who knows. will let everyone know if anything changes.
Posted from Mbworld.org App for Android
Old Jan 8, 2013 | 09:44 PM
Texas993's Avatar
2005 G500, 1995 E300D, 1993 500E, 1997 RUF Turbo R
Where do you live that you can get 93 consistently?
Old Jan 8, 2013 | 09:48 PM
99C43n843's Avatar
1999 C43 AMG
I live in Charleston, Sc. I didnt think there was a shortage
Old Jan 8, 2013 | 09:54 PM
AMGC43's Avatar
W202 AMG C43
I'm not following this. WHat is the SDS? a genuine MB scanner that let you play with few factory set/tune for the ECU? Or is a tuner device (which I don't beleive it is) ?
The StarDiagnose has this option as well? If so, under what group can I found it?
Old Jan 8, 2013 | 10:01 PM
99C43n843's Avatar
1999 C43 AMG
SDS is the factory scan tool. im a dealer tech. its a control unit adaptation in the M.E.
Old Jan 9, 2013 | 07:54 AM
Texas993's Avatar
In Dallas we have 93 too. But I often go to OK, CO, NM where they don't offer 93, only 91. I am particularly sensitive to this on my Porsche (RUF).
Thanks for your comments here and elsewhere. I wish that we had more techs on this forum!
Old Jan 9, 2013 | 02:33 PM
LawRens's Avatar
43
Would you happen to know what "default" is set to run on (for octane)? The manual & gas lid state to run 91 octane at minimum, but I'm sure MB engineers took into account there would be those few people who would ignore the recommendations; henceforth why I will assume that "default" is 87.
Old Jan 9, 2013 | 02:51 PM
99C43n843's Avatar
1999 C43 AMG
im not sure what the default setting parameters are exactly, but i would imagine it would probably be of the sorts if not equal to or less than 87 octance, but i dont think its for the people who are going to run the cheaper gas because they dont want to but as to like the *note said, countries with poorer fuel, so who knows there maybe some countries with 50/50 gas/water mix....who knows lol. its been a a day since i changed the setting, not sure if anything really has been noticed.
Old Jan 10, 2013 | 05:50 PM
speed43's Avatar
1999 C43 Amg
Pease keep us posted, would be nice if your car picks up some power. Btw, I have a question I like to ask since you're a tech. Would it be ok if I ask you to email me please? If yes it's gobulls1234@(gmail.com) thanks.
Old Jan 10, 2013 | 06:02 PM
99C43n843's Avatar
1999 C43 AMG
emailed you.
Old Jan 16, 2013 | 12:00 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Umm. Results? Notice a difference?
I'm in TN. Only use 93 octane shell v-power in all my MB's!
Old Jan 28, 2013 | 10:17 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
You just detuned your car by putting it to 93. Those figures are RON octane. Do a Google search, 93 RON is about the same as our 89. Default setting is actually 95 RON. By setting it to 93 you successfully detuned your car. That's why in that window it says "For countries with poor fuel quality".
Trust me, I'm a dealer tech and did the same thing on my c43 and ml55 the first day I got each. When I found out the real truth, I switched it back... very noticeable difference! They both felt like a new, way faster car after putting it back.
Old Jan 28, 2013 | 11:25 PM
99C43n843's Avatar
1999 C43 AMG
im a dealer tech too. just read the whole ron to octance conversion thing online. good info. didnt know that. and I see what you are saying. but my only question is how did you find out what the default # was. bc when I go into my sds its just says 93, 91, 89, default. just curious to where you found 95 to be default.
Old Jan 28, 2013 | 11:28 PM
99C43n843's Avatar
1999 C43 AMG
going to switch it back in the am and see if I notice a difference. I havnt really noticed any real difference from putting it to 93. guess ill see what default does.
Old Jan 29, 2013 | 12:17 AM
benzslo's Avatar
I was just at training in December, advanced diag update class, looking through the manual for the 276 and I saw it specified 95 octane ron. I asked what that was about and they explained Ron is pretty much what the rest of the world uses etc and that that engine isn't special, most all our cars call for 95 Ron (our 91 premium)
It got me thinking, I was never happy with the c43 or the ml, just didn't seem quite as strong as other ones I would drive. I switched them both back and it was immediate and very noticeable difference, especially off the line! Lots more torque in the mid range, it really detunes it by doing that, at least on those particular models. The c43 could just barely power brake before, now it can light the tires from a stop.
Old Jan 29, 2013 | 12:23 AM
99C43n843's Avatar
1999 C43 AMG
good deal. what state you work in? im in sc. since ive changed it I havnt really been able to drive it to really tell. always traffic to and from work. but I will definitely change it back. it all makes sense. thanks for info.
Old Jan 29, 2013 | 07:38 AM
benzslo's Avatar
I'm in MN. Usually go to the Chicago training center. I'm just glad I got it changed back!
