Larger Sway Bar for C43
Old Mar 6, 2013 | 06:02 PM
MGPAMG's Avatar
16Vs, 190 SL, G, SLK, CLS, E, C Black Series, SLS
I want to put a larger sway bar on my car from a different AMG. Can the CLK55 fit or something else? Does anyone have the diameters of different sway bars from the different AMGs of those years? Any input would help. Thanks
Old Mar 6, 2013 | 11:33 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
The only larger front option is from a SLK32 (30mm), but you'd need to check compatibility (MAY be a different total length, same mounts and shape though).
Depends on what you're looking for in terms of handling. Any upgrade on the rear sway bar I'd recommend fitted a LSD first as it would otherwise increase rear wheel unloading during cornering and reduce corner exit speed.
Factory bars are 28mm front and 18mm rear, H+R and Eibach bars are the same size.
I've settled for a custom 22mm rear bar and left the front alone, seems to be a great compromise, handle is much closer to neutral than factory spec.
Old Mar 7, 2013 | 01:25 AM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
THIS is what I've been thinking about lately, and what prompted my post about the Eibach sways. Can you elaborate on this? How custom? Totally fabbed? How much did it end up costing? I was thinking that a thicker rear would help take out some of the crazy understeer we get, but 22mm seems massive!
Old Mar 7, 2013 | 04:23 AM
DRBC43AMG's Avatar
I would assume with the crazy understeer you need a crazy size sway bar... I have heard, but stand to be corrected, that changing the rear bar is a real PITA due to lack of access and tricky shape.
Old Mar 7, 2013 | 05:26 AM
dearlove's Avatar
190e & c36
Front bar off w208 clk55 fits, 32mm
Old Mar 7, 2013 | 06:55 AM
DRBC43AMG's Avatar
Now that is interesting... What about the rear bar? I thought the w208 used the same chassis
Old Mar 7, 2013 | 07:58 AM
dearlove's Avatar
190e & c36
Not too sure about the rear, I would test it myself but I can't even find a front bar in Australia...
Old Mar 7, 2013 | 12:30 PM
nd4spd13's Avatar
Yep. Heard the whole rear subframe has to come down. But that'd give me an excuse to fit my SS brakelines and fix the leak in my dif while I'm back there
I find that very interesting too. Everything I've heard says that the 208 is the same as ours. Especially a 4mm difference. Don't know if the 209 could fit at all, but finding something from a 209 black would be pretty sweet i'm sure
Old Mar 7, 2013 | 07:43 PM
Ausmbtech's Avatar
I'm 99% sure the CLK55 has the same sway bars as a C43, I cant find anything to say otherwise but I guess if someone measures one I'd be very interested to know.
Changing the rear bar is much more difficult than the front to change. It can be done by lowering the rear subframe (removing it it still the best way) but I would recommend for more inexperienced people to give to your mechanic to change instead.
I had a bar made by Shelby sway bars in Australia (I supplied the original as a sample).
It does still require some fab work with the brackets, I'd suggest just 20mm unless you're looking for a bigger handling change.
****Just to let you know that about 2 yrs after the sway bar change that I broke the RHR swaybar mount off the body. By design the RHR mount is much weaker than the LHR. I cant be sure if it was a conincidence or due to increased loads. Realisticly driving into a steep driveway or parking on a greatly uneven surface puts more load through the swaybars than driving it on a race track but you've been warned****
As a side note, I've got a theory that fabbing a much stronger front swaybar mount would be almost as effective as a bigger sway bar as they do flex alot in normal operation.
Old Mar 7, 2013 | 07:49 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I broke the same mount with the stock sway bar. Had to drill it out to replace.
Old Mar 8, 2013 | 12:55 AM
MGPAMG's Avatar
+1
Old Mar 11, 2013 | 03:10 AM
23K's Avatar
23K
I measured the front sway on my 99 C43 at 30mm!
Cheers
Old Sep 8, 2013 | 06:02 AM
raw1879's Avatar
Mercedes C55 AMG
my front bay is 32mm and the rear is 18mm
Old Sep 8, 2013 | 06:10 AM
KJI3jflarryfe93's Avatar
is yours factory or aftermarket?
if i'm not mistaking, many years ago someone tried an ML55 swaybar on his c43 dude never reported if this bar fitted or not?
Old Sep 9, 2013 | 06:02 PM
DRBC43AMG's Avatar
Normal, he swerved off the road On an other note, to eliminate or reduce understeer you need to brake into the corner to get weight transfer. Once you understand how that happens, the handling is transformed and everything becomes easy.
Old Sep 10, 2013 | 07:26 PM
Dziner82's Avatar
99 C43 AMG, 2001 CLK55 AMG
I wouldnt say it becomes "easy", maybe 'much better'
Old Sep 10, 2013 | 11:56 PM
PJmak's Avatar
My friend had a ML swaybar on his 202. His user name is RemoLexi on club202
Old Sep 11, 2013 | 03:30 AM
ask him if it was thicker than w202 sweybar?
did it fit w/o modifications?
Old Sep 11, 2013 | 05:42 PM
DRBC43AMG's Avatar
+1
Old Sep 11, 2013 | 05:58 PM
cm60k's Avatar
All "W163 ML’s" uses the same sway bar, what the special thing with it..?,
is it more thick than the one we have....??
ZAYED,,
Old Sep 11, 2013 | 11:54 PM
Oh Kowalski, how quickly you forget threads you have posted on...
https://mbworld.org/forums/c36-amg-c...y-bar-kit.html
Old Sep 12, 2013 | 05:00 AM
I'm at an early stage of getting alzheimer
I do fogget stuff.
sorry
Old Sep 12, 2013 | 05:02 AM
cm60k's Avatar
No problem on that, i think im starting to follow you as well....-
ZAYED,,
Old Sep 12, 2013 | 01:28 PM
LawRens's Avatar
43
I do fogget stuff.
sorry
I sincerely hope that you are joking about this.
Old Sep 12, 2013 | 03:31 PM
nope!
I'm not what I used to be anymore
