Wheels/Offset?
Old Apr 4, 2013 | 02:59 PM
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG/2021 Toyota Tundra Crew Max TRD Sport Premium
Wheels/Offset?
Hey everyone. Will 18x10 et40 wheels fit the rear of a C43? Has anyone tried this size? Thanks.
Old Apr 5, 2013 | 07:47 AM
popey24's Avatar
C43 AMG 5.5 - 396.4HP
Depends on your tire... you might get problems at the inside of the wheel housing when compressed and/or at a part of the cars body on the bottom when rebound.
Old Apr 6, 2013 | 02:21 PM
nkctb7's Avatar
Thanks for the info. I was planning on running 265/35's and I figured that it might be pushing it. I don't want to run into any rubbing issues as I'm dropping it with a Vogtland/Koni setup. I'm also running #4 pads in the rear with MBArts rear camber arms. I'm curious as to what the widest wheel/tire/offset setup is for a C43. Any input is appreciated.
Cheers
Old Apr 6, 2013 | 02:40 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Cheers
I am running 9.5 with 265/30 with ET of 35 in the rear and I am CLOSE to rubbing, there is someone one here who is running a 10" in the rear with 275 or 285 but I can't remember who it is and what rim/tire they are using or if it required modification to get it to fit.
Old Apr 9, 2013 | 01:57 PM
popey24's Avatar
The problem is all these tires on the market have a wide range... with same tire you can have a difference of about 40mm (1.5'').
I was running 285/30 on 10x18 in passt. Now my new tire is of same dimension but it is 309mm wide (I don't know why they still call it 285, in my opinion it is a 305 size).
I put it on an 11x18 wheel with offset 24. Maybe I will go down to offset 20 but I don't think so. Still preparing my fenders...
Old Apr 10, 2013 | 02:04 AM
DRBC43AMG's Avatar
From: CH = Land of mountains, cheese, chocolate and watches
What are you doing to the fenders? Widening or solving a rust problem?
Old Apr 11, 2013 | 04:41 AM
popey24's Avatar
Those tires won't fit with original fenders.
Concerning the 265/35... take care about the rolling circumference. I drive that dimension as winter tires and they fit fine. A friend of mine had same dimension as summer tires and he had problems with ABS/ESP electronics. So ask the tire manufacturer for rolling circumference befor you buy.
Old May 3, 2013 | 02:03 PM
FrenchBenz's Avatar
1999 MB C43 AMG
Guys,
Quick thread revival... I'm looking at a set of rims for the car. Can you tell me if they'll fit:
Front: 18x8.5 ET+44 5x112 bolt pattern
Rear: 18x9.5 ET +46 5x112 bolt pattern
Thanks in advance for the answer!
Old May 5, 2013 | 04:02 PM
FrenchBenz's Avatar
1999 MB C43 AMG
Anybody???
Old May 22, 2013 | 06:14 AM
popey24's Avatar
Won't fit at the inside. You will need spacers front and rear (10mm should be fine)
Old May 22, 2013 | 07:52 AM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
I'm running 18x10 in the back. I've never dealt with spacers and don't even know where I'd find them. These were on the car when I bough tit. I've removed the wheel and it's mounted directly to the rotor, if that says anything.
Edit: AMG r129 SL55 2-piece, staggered, 18x8.5 in the front. I THINK the offset is 25
Old May 22, 2013 | 08:23 AM
FrenchBenz's Avatar
1999 MB C43 AMG
Thanks for the reply guys... I just picked up a set of AMG Monoblock II off an W210 E55. They should be here within a week or so. It should be a no brainer this time
Old May 22, 2013 | 11:05 AM
DRBC43AMG's Avatar
Good and sensible choice which will give you NO problems at all and will fit perfectly Just expect to have a slighly harsher ride....
Old May 22, 2013 | 11:10 AM
Sulaco's Avatar
It's for this reason that I'm pretty sure I'm going to be selling my 2-piece Aeros! Sick of the overly harsh ride! Probably missing some HP and MPG because of these heavy/wide wheels too!
Old May 22, 2013 | 11:52 AM
FrenchBenz's Avatar
1999 MB C43 AMG
I already have 18'' and and fairly low-profile tires so that should not change much hopefully. I don't mind the harsh ride anyway, I'm still young enough
Old May 22, 2013 | 09:00 PM
nkctb7's Avatar
I really like the rear wing on your C43. What brand is it if you don't mind me asking? Thx
Old May 22, 2013 | 09:29 PM
Sulaco's Avatar
Lorinser. I forget exactly which one. Someone who had this car before me put some sweet stuff on it. And took immaculate care of it.
Old May 22, 2013 | 10:39 PM
nkctb7's Avatar
Thanks! I have to say that your spoiler is one of the nicer one's that I've seen. It looks very sharp and curves well with the C43's lines.
