That is IT! WHAT DO I DO WITH THIS F@#$%^& SPLASH GUARD!
Removed that guard shield "3" years ago, without any issues, plus need more air flows around the oil pan to cool it,
cause much hot air comes down from the Engine side & not escape or recycle in the dead area around that shield.....
ZAYED,,
Whilst I am not an aerodynamicist, I understand that generally flat surfaces are better for airflow than open spaces. I dunno how much work was done during the car's development for engine bay and underbody airflow, but you'd think Mercedes put the splash guard there for a reason.
I can assuming that MB put that shield as a protection reason from anything could hit the Engine from bottom side,,
they open an vent hole to the shield for the direct air flow,,
but i think this hole NOT enough to get more air to cool the bottom Engine,
and if you noticed; the shield area get the stuck hot air without in/out vent cycle.....!!
ZAYED,,
i may agree with some benefit with a high speed, but that may during to the normal or cold air, NOT with a hot air,,
I tried that either in mine,, you know; in our country, sometimes the temp. reaches "50-52C",
when i put my hand in the shield area, extremely damn hot air flows there, comes from the Ex. manifolds & the oil pan,
and NOT escape easily from that area,,
our oil pan does not has any kind of gasket between the upper & lower,,
silicone paste is the only way to joined them together,,
i had an oil pan leaks from that narrow area many times, when i removed that shield, no any leaks from that day,,
i can guess, that shield can cause some heat issues, by over stuck hot air in that area,,
maybe that could NOT that noticed with a normal or cold countries....
!!ZAYED,,
Secondly I'd modify the splash tray in a similar way to a factory W202 C250TD tray (no they aren't a direct fit, but if you want to buy one you can drill new mounting holes). The c250td tray has a cutout and a 1.5" piece of plastic hanging vertically infront of the cutout. This creates a area of low pressure at speed and increases the airflow through the intercooler. Doing the same thing to our tray in a position just after the radiator would aid cooling too whilst keeping the splash tray.
See attached pics for comparison
A couple other anecdotal notes on aero - closed wheel racecars, like Le Mans sportscars, are much more aerodynamic than open wheel racecars.
Recently as I have gotten Porsche 911 fever, I've been reading up on them, and newer models have flat undertrays - or rather, they have plastic bodypanels beneath almost the entirety of the car, I understand.
My winter beater A4 Avant's splash guard has NACA ducts in it - must mean they did some engineering work on underbody airflow to help evacuate engine bay heat.
I tried all types of an M113 fan, they won’t fit,,
is that "W210 E300td" fan fit without any mod....??
ZAYED,,
there is no free space for it, how do you fit it, do you have some pics. for installation...??
ZAYED,,
that avoids clutch to set properly.....!!!
ZAYED,,
1) The edge areas that hits the Radiator (see the scratches in black),
2) The small piece in the clutch base, i cut it, to let the clutch set properly,
* i think the "W210 E300TD" fan would fit to all "W202" & "W208" 4 or 6 cylinder, & all "W210" 4-6-8 cylinder,
but it will NOT fit to "W202" & "W208" 8 cylinder...!?!,
*pls. if anyone got some experiment about this, share it with us....
ZAYED,,
