AMG brake upgrade question?
with my old front 2 pot brake kit, could this kit be retrofitted on rear axle with 334mm rotors without cutting dustplate?
this modification must improve braking on my car?
i was thinking if they could fit on rear axle with the larger diameter front rotors and no dustplate cutting?
as you know; the holes of the calipers screws distance between front & rear are different, need to fabricate a new bracket,
then you can put 330mm Rotors from SLK55 or SL55.....
ZAYED,,
