C43: Billstien HD vs Koni Adjustables
Reason I'm asking, is I installed the Konis with the euro springs, and even on the softest setting, it's still pretty damn firm, jarring at times even.
That, and getting onto the freeway last week, stayed to the side to avoid the usual ruts and what not, didn't see a divot in the onramp, and pretty sure I blew both front struts, as noticed by the front end "float" when driving on the freeway afterwards. And they've only been on the car for about 2 months. *Sigh*.
So I'm going to go through the Koni warranty process, but, do people prefer the Konis or the Billys?
is that a pothole or something?
if you blew your front shox you must have hit your car very hard?
i think euro springs are to high for koni's, sportshox have a shorter length vs factory shox, this might be a mismatch for you?
i like my koni's, b4 i bought them i was worried that i might get rattling inside cabin becouse of their stiffines.
there's no rattling thank god and i run them on the stiffest settings.
however i have fitted vogtland springs and this is a good set up.
euro factory set up is very firm, this is sensed on bad surface roads, now that my car is tighter with all new suspension parts on front and rear axle, car will be more planted on the road and all bad surface roads are sensed even more now.
everything is a compromise if you want a tight car
You make an interesting point about a mismatch, when I bought the shocks, they were for the C43, but probably for the US factory height C43, and NOT the euro C43. Crap. However, this is the same Koni that many have reported using with Vogtland springs, which ride even lower than the Euro springs, so I honestly don't believe that's an issue.
Can you tell me which Koni part numbers you have installed with your Vogtland springs? I tried turning mine to the firmest setting, and the ride was so bouncy I had to turn it back. Also, it's my understanding that the euro springs are the same spring rate as the US springs, only shorter.
K-8041-1315SPORT
K-8041-1316SPORT
vogtland is #952079
i don't think koni have 2 different shock body lengths for euro vs US sport shox.
i like the stiffest setting as my car feels tighter on handling like a gocart on speed.
lucky you, you have lifetime warranty on koni's in USA?
mine are only 2 years warranty.
what a difference between US and euro consumer rights
I'm going to work on getting a warranty claim started tomorrow.
Has anyone driven the Billys and Koni's back to back? Preference?
Good luck with Billy's and keep a close eye on the lower mounting bushing. On Konis its solid but on billy's it's rather soft rubber. Also consider getting the B6s as opposed to the B8s, as those are more designed for a hight like the euro springs.
Is there any way to beef up the lower bushing for the Billy? I ordered this part number: 24-018548 which should correlate to the sports, meant for lowering springs as opposed to the HDs which came stock with the US springs.
I have a post in one of the older shock thread with the different Billy shocks and the heights they're made from, as told to me by a representative from Bilstein. I'll see if I can dig it up
Are the B's just softer than the K's? Even on the softest setting I felt like the K's were really rough. Portland has some rough streets, train tracks, and the ride was really quite jarring at times. My friends XKR rides better than my car, ha. Hell, my MINI rides a little better.
I've already ordered the B's, if I end up not liking them, I can always take them off and sell them. And I'm pretty sure I ordered the right part number, there's only the HD and Sports, right? I ordered the sports/yellow.
I believe there's a stock replacement line-B4s, HDs-B6s, and Sports-B8s
I like the height of the euro springs and didn't really want to go much lower than them. I researched all of this over and over again, but I guess I never thought about how stiff the springs would be. Someone mentioned that they are the same spring rate as the US, only shorter. That should have been a big indicator right there, ha. If the Billy B8's are stiffer than the Koni's on the softest setting, then this is gonna suck.
I'm not in a position to dump a lot of money on suspension on the car right now, hence the reason for going with the cheaper Billys. I guess I'll just install them and go from there.
I don't have any special camber bolts/arms, etc. I wanted to get Kmac but both my mechanic advised against it saying that it was unnecessary unless I was going to track the car. Too squeaky in their opinion and they got close to factory alignment as well without them.
Thanks for your input!
My c280 are now using B8 sport and Eibach pro-kit.....those suspension combination give me the road sense is soft.....same as Depuineuf, i also has some inside camber wear on the tires (both rear tires) when the car is loaded, so i just change the rear spring back to origianl and the problems had been solved (however, my both rear Eibach spring become no use).
oh, forgot to tell is I'm currently using AMG front 8.5", rear 9.5" R18 wheel, 235 35 R18 front and 245 40 R18 tires rear.....I think that should be the reason to cause such problem (too big)
Your 9.5" wide rears probably ran 275s stock on the S-class, so a 245 tire on them cuts the tire width by over an inch, hence the stretched look.
if your daily driving the car and not doing any track days or autocross i would say there is no need for the Koni adjustables. I have the Billy sports and they are not firm enough for my autocross and track day events, but the daily driving is just slightly firmer than stock, not terribly harsh. Im on euro springs.
