Reliability C36 vs C43
Old Sep 15, 2003 | 11:18 PM
Chedman13's Avatar
2014 Mercedes-Benz GL63 AMG
Question Reliability C36 vs C43
I currently own a 1994 S600 Coupe and 1993 600SEL. Both are amazing cars but it is time for them to go.
I am looking to purchase a C36 or C43 to replace them. My only decision factor between the two is reliability. I am only looking at the 1997 C36 vs any C43 (probably not 2000 since they are so rare).
I have read this forum and found that these cars do have similar problems that my W140s had. They are so darn expensive and so darn expensive to upkeep. But, it's a mercedes. And now that I've driven a benz, I can't go back.
Both of them got new transmission, and even one of them had the cylinder heads replaced. All work was done under warranty (I bought the extended warranty when I purchased them, work done on both cars well exceeded $10k). I'm sure the dealership wasn't happy about that. I didn't pay a penny.
Additional question:
What is the max mileage on either car that I should purchase to be "safe".
I'm looking to keep this thing for atleast 10 years.
Thanks in advance.
Old Nov 13, 2013 | 07:28 PM
kirkie's Avatar
C36 AMG
I have a 95 C36 AMG, it has been very reliable, but I have also spent money on it to keep it in good shape, a good C36 is an amazing machine, I love mine I fully recommend one
Old Nov 13, 2013 | 08:11 PM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
Pick your poison. C43 has transmission issues but the M113 is pretty reliable. Standard fare is your normal issues: MAF, O2 sensors, oil leaks from the valve covers and oil cooler, etc. Nothing terrible and parts aren't too terrible beyond the factory brake rotors. Some have fitted W203 Sport rotors to help cut down on that cost.
Obviously I don't have much experience with the C36, but it seems that wiring harness and head gasket issues are the most common major failures. Not sure if the 5 speed on the 97 C36 has the same issues as the C43.
Old Nov 13, 2013 | 10:01 PM
Somalia757's Avatar
1995 AMG C36
I own a 96 C36 w/ 138k now, nothing really major so far. Some clear coat peeling from the sun exposure. Has been in my family since about 2000.
Old Nov 13, 2013 | 11:09 PM
Benzini's Avatar
I have had both and still have two C43s. The earlier C36 with the 4-speed may have bad wiring harnesses and that cost a mint to replace. The later 5-speed cars do not appear to be affected.
Both the 5-speed C36 and C43 will have transmission failure if the factory recommendations are respected. Instead, change the synthetic oil and filter every 30K miles and shift "with your right foot" rather than letting the clutches do all the work.
The usual things will, as indicated above, fail: MAF, and sometimes the main computer and there are no replacement parts, MBNA will "repair" yours for a mere 1500 bucks. Where were those guys when the Obamacare website was being put together?
One more thing: keep the car garaged because the sun damages the roof liner and it collapses on you.
Other that that, both cars are great, lots of fun and handle like go karts.
You can get a 1999-2002 E55 for similar money and it is a better car overall, with less issues. In fact, it is virtually bullet-proof and will leave the C's in its dust. I have one too and it is completely trouble-free.
So far!
Old Nov 13, 2013 | 11:31 PM
RPB's Avatar
RPB
I'm somewhat biased towards the 95 /96 C36. It will just require the engine harness in most cases as previously stated. These years were very robust all around, but it def helps to find a maintained example w/ records. GL in your search.
Old Nov 14, 2013 | 01:17 AM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
Well this is a heck of a thread revival....
Old Nov 14, 2013 | 06:47 AM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Haha wow. 2003? Pretty sure he made up his mind.
Old Nov 14, 2013 | 06:25 PM
RPB's Avatar
RPB
Oh wow, I thought it said 2013. Too funny.
Old Nov 14, 2013 | 10:24 PM
ECTurboGSX's Avatar
Haha. In that case, don't buy one right now. You'll be able to pick one up for under 10 grand in 2013.
Old Nov 27, 2013 | 02:33 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
i have alot of experience on both cars, c43 is much more reliable and will be cheaper to own/maintain.
there's also alot of perks with the 43, alot of things happened in the 98 facelift. c36 is a cool car still.
