Greeting to all!
Before 1 month i bought used and japan imported C43 AMG..
The vehicle is almost perfect! low mileage.. less then 80000 Km (50000 miles)
everything is working , NO leaking , NO vibration , NO strange or funny noises , NO electric failures, replaced most of the consumable parts with OEM : Spark plugs, flushed gear oil, changed petrol filter..etc.
Stopped the car for two days only & today i got this thing that spoiled my day!
tho, the car has no issues at all till now.
but am worried that it would be something that required to be checked and repaired. if any 1 got any clew or idiea about it i would be glad to read it.
Thanks & Regards.
[IMG]
[/IMG]
tho, the car has no issues at all till now.but am worried that it would be something that required to be checked and repaired. if any 1 got any clew or idiea about it i would be glad to read it.
Thanks & Regards.
[IMG]
[/IMG]DRBC43AMG
close
- Join DateMar 2010
- LocationLand of mountains, cheese, chocolate and watches
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG + Ultima Can-Am sold)
Liked:323 Times in 268 Posts
Welcome aboard the forum. Looks like you have a great C43. It seems that Japan has some very fine vehicles stashed away in that part of the world and I'm not talking only MB's
If you have a problem you need to explain a bit more. Also your photo was removed so we have no idea what it is....!!!!
Thank you DRBC43AMGOriginally Posted by DRBC43AMG
Welcome aboard the forum. Looks like you have a great C43. It seems that Japan has some very fine vehicles stashed away in that part of the world and I'm not talking only MB's If you have a problem you need to explain a bit more. Also your photo was removed so we have no idea what it is....!!!!
i have no idea why the photo was removed
am uploading it again..
The manual was not supplied when i boughth the vehicle..
DRBC43AMG
close
- Join DateMar 2010
Looks like you need a oil, filter change and service, not unless you have proof that is was done recently and the workshop forgot to reset the counter. Normally you can do around between 10-15k kms between services, but it depends if you drive in city traffic (more frequent services needed) or open highways.
I don't know if Japanese market C43's are different than the others. I doubt it though.
I have done a major service recently when i bought the car, but as you said most probably the resetting part was forgottenOriginally Posted by DRBC43AMG
Looks like you need a oil, filter change and service, not unless you have proof that is was done recently and the workshop forgot to reset the counter. Normally you can do around between 10-15k kms between services, but it depends if you drive in city traffic (more frequent services needed) or open highways.I don't know if Japanese market C43's are different than the others. I doubt it though.
so there is nothing actually to be worried about, DAMN i almost thought to sell the vehicle!
Thanks lot, now i can live in peace
it means you need an "A" service in 8 km's.
Sulaco
close
- Join DateMar 2005
- LocationAmerica
- Vehicle(s) I drive1999 C43 AMG, 2005 E55 Wagon
Liked:194 Times in 156 Posts
If you've already done the service then you just need to reset FSS. That's the counter that tells you when to service/change fluids. Google it, simple procedure that involves turning the key in and off
DRBC43AMG
close
- Join DateMar 2010
Not as obvious as it should be. I tried many times using different possibilities but with no success. The only way is with Star.
ExploreMBWorld Fanatic!
Quote:
when I used to have my c43, I saw my indie tech reset it pretty simply, but I don't remember the procedure. I think it involved some button pushing on the cluster.Originally Posted by DRBC43AMG
Thank you every1 for the support.
The service indicator was reseted following this guidelines (taken from Benzworld.org)
1 - Get in the car and close all the doors.
2 - Put the key in the ignition and turn it to position #2 (Dont start the engine).
3 - Press the odometer reset button (O) 2 times so that the FSS countdown (Service Indicator) appears.
4 - Turn the key back to position 0 (off, Dont remove it).
5 - Press and hold the reset button (O) while turning the key back to the #2 position. Keep holding the reset button until you hear a beep between 5 to 10 seconds.
Everything should be reset. And from my experience it need to be done quick otherwise it wont work.
Regards...
Regards...
