Mercedes-Benz W202 1JZ-GTE VVT-i Project
Old Jan 1, 2014 | 10:43 AM
Nowack's Avatar
Hi to all!
Yes, it's not an AMG version, but still it is not stock, and power output is near to AMG versions.
So, it was 96' Mercedes-Benz C230 Kompressor W202 MT (M111.975, 2.3 Kompressor, 193 bhp).
The power was not enough, and I don't want to tune already too old stock engine. Another variant was to make it turbo, but nobody in Russia can tune it's ECU properly. So me and my friend Bear Dima decided to swap Toyota 1JZ-GTE VVT-i engine and Toyota W58 5-speed Manual Transmission.
Few words about this engine:
R6, 2.5 l, single turbo, vvt-i system - 280 hp & 380 Nm full stock engine.
To be honest - it is probably the first W202 with 1JZ-GTE Engine and MT in the world. Another W202 with this engine i founded in Thailand, and it was NO information at all
So, we have ZERO important information about the swap but we STARTED the swap works in the end of October 2013.
My 1JZ-GTE Engine
So, the very first part was putting off stock engine & gearbox. Photos:
Stock look under the hood
Old Jan 1, 2014 | 10:44 AM
Nowack's Avatar
Next step was fitting 1JZ engine under the W202 hood:
It was enough space as you can see
Old Jan 1, 2014 | 10:49 AM
Nowack's Avatar
Custom exhaust system
So the next step was exhaust system.
I wanted to make 76 mm (3") exhaust from turbo, but my friend Bear Dima told me, that it will be TOO load for every day use. So i trusted him, and we make 63mm(2.5") exhaust. The sound is good now, and I'm happy that I listened to my friend and didn't make 3" =)))
Photos:
DOWNPIPE, so beutyfull, isn't it?
MAGNAFLOW muffler
Full exhaust
Old Jan 1, 2014 | 10:51 AM
Nowack's Avatar
deleted.
Old Jan 1, 2014 | 10:52 AM
Nowack's Avatar
So check out Exhaust sound, full stock engine, turbo, boost etc.
If you are interested in this project, I will post the whole story))
Old Jan 1, 2014 | 12:33 PM
Saaboteur's Avatar
eclectic assortment of cars
Please post the whole story!
Old Jan 1, 2014 | 02:44 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
That is freaking awesome! I don't care if it is no longer MB or AMG, an awesome w202 is still awesome.
I've always wanted to drop a big modern American v8 and a 6 speed in one.
Also this
Old Jan 1, 2014 | 06:28 PM
eFifty5AMG's Avatar
2004 E55
X2, awesome project!
Old Jan 1, 2014 | 08:24 PM
Nowack's Avatar
Brakes
So, with much more power, then stock engine, we decided to change brakes. We take brakes from E420|E430 W210. E420|E430 W210 weights 200 kg more then my car, so for my car they have to be good.
W210 E420|E430, 330 mm VS. W202 C230 Kompressor stock, 290 мм
Ну и наконец передняя тормозная система собрана :ay:
Old Jan 1, 2014 | 08:25 PM
Nowack's Avatar
Defi gauges
- Water temp
- Oil temp
- Boost
Old Jan 1, 2014 | 11:55 PM
cm60k's Avatar
Nice brake upgrade,,
W210 E420 uses "316mm", #: "210 421 17 12"
W210 E430 uses "300mm", #: "210 421 22 12"
which model are these "330"...??
ZAYED,,
Old Jan 2, 2014 | 01:27 AM
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
Absolutely killer job! Keep us posted!!
Old Jan 2, 2014 | 08:30 AM
Nowack's Avatar
ZAYED,,
There were two types of Brake system on this models:
316x28mm & 330x32mm :
24.0132-0159.1
Old Jan 2, 2014 | 09:15 AM
cm60k's Avatar
I think you refer to "330x32" #: "210 421 23 12", for (CLK430/E430 4matic/SLK32).....
ZAYED,,
Old Jan 2, 2014 | 09:29 AM
Nowack's Avatar
So, this was first EVER start of 1JZ-GTE VVT-i on my W202. No intercooler installed, straight pipe from turbo to intake manifold. Also without exhaust system at all. A lot of work was done, but a lot of work was left..
Old Jan 2, 2014 | 09:34 AM
Nowack's Avatar
Also this
The journey of an epic engine swap - Mercedes Skyline - Vmax - YouTube
WOW! Thanks for link! Great project
Old Jan 2, 2014 | 09:38 AM
Nowack's Avatar
New 63mm (2.5") Exhaust system with Magnaflow muffler was installed. Check out an exhaust sound. I like it...
Old Sep 28, 2014 | 10:35 PM
hipnimahop's Avatar
C230 na auto w202
amaizing, I want to do the same with a 2jz I have a w202 c230 auto . please help me
how did you manage for the engine mounts ?
what differential and axles did you used ?
how hard on 10 would you rate this swap 0 easy 10 really hard ?
Old Oct 3, 2014 | 12:41 AM
svt ricco's Avatar
1999 C43 AMG
Not the first 1jz swap.. I remember reading it a couple of years ago. If I'm not mistaken, the car was from Indonesia or Hong Kong. But yours is more detailed on the build. I like the way it sounds by the way. Please post hp numbers after.
Old Oct 3, 2014 | 03:35 PM
Pagz's Avatar
C43 w/clk55 Organs
Good work!
I think dokotela did jz a few years back too...
http://www.club202.com/forums/showth...ally-back-home
Old Feb 1, 2018 | 11:01 PM
James Malancea's Avatar
1998 Mercedes-Benz C230 2007 Audi A8 2012 Audi Q5
Engine mounts.
What kind of engine mounts did you use? And what drivetrain?
Old Feb 2, 2018 | 08:03 PM
RPB's Avatar
RPB
I’ve nothing but respect with regard to how you guys are willing to try new things and not take no for an answer. Trial and error is the only way something gets accomplished. I feel things are different in the U.S. these days and we tend to have a pessimistic view in making a build like this come to fruition.
I’m from the UK where they have an annual MOT test. Is it the same in Russia? I wish you the best of luck with the build and look forward to seeing the results!
Cheers,
-Rob
