Engine started making ticking noise
As im driving with my windows open i can hear the noise bouncing off walls as i accelerate. I should mention that at idle right after startup the engine sounds normal but after a minute or so it starts quietly ticking on the driver side somewhere.
My valve cover is due and is leaking a bit and i can tell the oil is slightly reaching one or two of the plugs on that side. Could this a be a missfire problem? Would it make the engine sound that?
Oh yea btw C36 or C43?
The lifters in my 99 tick sometimes, but it has 268,000 miles on it. A fresh oil change hushes the tick for at least 5,000 miles. Of course, Mobil 1 0w40 only.
This is a 98 c43. I have about 165k on it atm and ive changed oil regularly. My last oil change was 300 miles ago but the click started maybe a month or so before that and its still there. I always use 0w40 mobil1
I dont know much about valves and all of that. Is that a big job?
Ive done a lot of smaller stuff on my car and i have some experience. Im wonfering if this is something i could do my self...
Lifters would involve removing valve cover, cams, but leaving the head on the engine.
Valves involves pulling the head off the engine.
But before you start jumping to conclusions, you need a 2nd opinion on the sound itself. Could you record it with your smartphone or something? Could still very well be something completely different.
Ill report back
The ticking noise you hear for a few seconds at startup is what im talking about. Its not there at idle but as i accelerate it starts doing it again and it can be heard clearly as i drive by
http://s5.photobucket.com/user/preja...aa8c1.mp4.html
I'd do an oil change first, just for kicks. If that hushes it, then you've got a different issue. Curious to hear what you refer to when you say people can hear it as you drive by.
But anyways, looks like ill be looking into 5.4s pretty soon
