Crankshaft Positioning Sensor?
Mine needs it too. It's intermittent but will ultimately always start. I'm luckier than most, from what I hear.
I say replace CPS and you'll be tops.
Hey Sulaco,
Hope all is well with you. Thanks for your input. I did order a OEM Bosch cps but it failed to fit as the guides on my wiring connection were different. Apparently the connection changed mid year and I have the '00 C43 sensor. If you're interested, I found OEM Bosch for $45 USD.
Cheers
Here is the link to the part that I ordered. http://www.ebay.com/itm/121218085703...84.m1439.l2649
This Bocsh #: "0261 210 141", refers to OEM #: "003 153 95 28" or 96 28", with 2 pins,,
the one you have to get should be "0261 210 171", which is OEM #: "003 153 27 28" or "28 28", with 1 pin.....
ZAYED,,
our friend (tsquare) have one F/S here: https://mbworld.org/forums/engine-pe...ml#post5937576
ZAYED,,
ZAYED,,
MB put that Extra guide in that postion, cause they using the same connector for the Alternator as well......
ZAYED,,
The results were more impressive than I had anticipated. Throttle seemed more responsive and that resulted in quicker launches. Definitely worth the $170 USD. I haven't had the car dyno'd yet so as far as the stated 27HP increase, I'd have to say that it certainly feels accurate. Jerry was highly recommended and I've yet to hear of an unsatisfied customer.
