Engine Cover Star Emblem
Old Mar 10, 2014 | 10:49 PM
mkoons's Avatar
1999 C43
Probably 50 percent of C43 owners have lost their engine cover 3-pointed star emblem. If you press on it, it will simply pop off. I have been told that a 2012 S series truck emblem will fit with a little grinding down of the prongs. I intend to go the local dealer and see what they have that would fit on the engine cover.
Some modifications would have to be done and the new emblem glued on.
Does anyone have experience doing this. Better than paying $200-300 for a new engine cover.
Old Mar 10, 2014 | 10:55 PM
svt ricco's Avatar
1999 C43 AMG
Before putting it on, put on 3-4 coats of high heat clear coat to protect the chrome from peeling off.
Old Mar 11, 2014 | 05:19 AM
popey24's Avatar
C43 AMG 5.5 - 396.4HP
I used an A-Class star from trunk (maybe 2mm more in Diameter)
Old Mar 11, 2014 | 01:47 PM
PJmak's Avatar
Ive had my c43 for 70k+ miles and the engine star looks new still
Old Mar 12, 2014 | 02:44 PM
fredtga's Avatar
w202
the newer style wheel caps, with the star emblem in chrome, these type of wheel caps are actually two parts: the base usually in a flat color and the emblem in chrome it's attached to it.
That emblem is just slightly smaller in diameter than the original c43 cover emblem. I used it successfully many times.
This is a wheel cap emblem used on one of my cars i had:
Old Mar 12, 2014 | 04:48 PM
svt ricco's Avatar
1999 C43 AMG
[/QUOTE]
what part number is this? I need some for a project too!
Old Mar 12, 2014 | 05:29 PM
mkoons's Avatar
1999 C43
Engine Cover Star
That wheel cap star looks great, are those real chrome or the usual plastic wrapped crap. What's the cost, can't be too much.
Old Mar 12, 2014 | 05:55 PM
KJI3jflarryfe93's Avatar
how did you make the star stick on plastic cover?
Old Mar 12, 2014 | 09:54 PM
mkoons's Avatar
1999 C43
Kowalski,
I have not done anything at this time. I want to go to dealership next week and look at the wheel cover emblems. I do not want to use a plastic film emblem, I need to see what the dealership has that would fit the cover. I will report back to all of you after I see what's available.
Old Mar 13, 2014 | 12:00 AM
cm60k's Avatar
I think the closest one from W221 trunk star, isn't...??
ZAYED,,
Old Mar 20, 2014 | 07:12 PM
mkoons's Avatar
1999 C43
Engine Cover Star
Finally found easy solution for replacing engine cover star emblem. Purchased trunk emblem for W221 S series from Pelican Parts for $25 shipped. It has 3 prongs in center of back which you could grind off and epoxy emblem on to cover. Instead I drilled 3 holes 5/16 inch diameter in center of where star would go on cover. Takes a little bit of measuring to determine exactly where to drill but its a perfect snug fit, didnt ever have to glue. It had been bugging me for months that my star had broken off, now I am happy!
Correction- final drill bit is 5/32
Old Mar 21, 2014 | 03:11 AM
DRBC43AMG's Avatar
Looks like à good solution. Thanks for posting
Old Mar 21, 2014 | 10:39 AM
FrenchBenz's Avatar
1999 MB C43 AMG
is the part # 221-758-00-58-M22 ?
Old Mar 21, 2014 | 12:36 PM
mkoons's Avatar
1999 C43
Didnt keep the parts package with part number but its a W221 S series trunk emblem. W221 would be up thru 2013 I believe.
Old May 5, 2014 | 04:32 AM
popey24's Avatar
Is there a photo of the W221 star mounted on the engine cover?
From my Information the W221 should be a little to big (85mm like the A class star, original is 80mm).
If the W221 realy is 85mm I will better try the wheel cap star (75mm).
Old May 5, 2014 | 01:00 PM
mkoons's Avatar
1999 C43
Engine Cover Star
POPEY,
I dont have any pictures, not good at doing that. I can assure you that the w221 truck star fits perfectly. After using a pilot bit drill the holes out to 5/32, it will fit snug, dont even need any glue.
Old May 5, 2014 | 01:27 PM
FrenchBenz's Avatar
1999 MB C43 AMG
Just ordered the W221 trunk emblem and will try to get it installed over the weekend. Will try to document and snap pics of install to show you guys if there is interest
Old May 7, 2014 | 11:17 AM
popey24's Avatar
Can you please measure the Diameter of the S-Class star please.
I covered my engine cover with carbon fibre and it Looks strange if the star is not Fitting now. Original size is 80mm. A-Class is 85mm and I think S-Class is 85mm, too.
I bought the wheel cap. The star is simply clipped in. Diameter is 73mm, so it is a Little smaller. But the star is not flat.
A class star is fully flat. S-Class I don't know.
Old May 7, 2014 | 12:14 PM
mkoons's Avatar
1999 C43
Engine Cover Star
POPEY,
W221 trunk star is 85mm & is flat. In my opinion it fits just fine. 73mm would definitely be a little small.
Old May 7, 2014 | 01:45 PM
FrenchBenz's Avatar
1999 MB C43 AMG
I would have but mkoons beat me to it
How did you warp your engine cover? 3M dinoc CF wrap? Does it hold well to heat?
Old May 7, 2014 | 03:34 PM
cm60k's Avatar
I think W221 trunk srat is good to go, isn't..?
some guys done that:-
http://www.benzworld.org/forums/w210...ver-badge.html
http://www.benzworld.org/forums/w210...ve-engine.html
ZAYED,,
Old May 7, 2014 | 03:45 PM
popey24's Avatar
I covered it with real carbon fibre and resin. The air intake tubes are just perfect. Airbox is quite good as well just some Little faults in the matrix. But I had some Problems with the front cover. Have some Little White/silver spots in the clear coat. Don't know if clear coat to thick or sanded to early or something else. One time the clear coat was fine when starting and after short time the pistol was spitting thick drops. Don't know the reason. Need to talk with some professional painter...
The front part also causes distortion after tempering in the oven. So I needed to heat up again to 60°C and Laminate some layers of cf on the inside of the cover to prevent distortion. It was a sweaty job but it works well no. No more distortion.
So S star is the same as A class one. I had the 85mm star in past and without cf it was ok but now with the cf cover doesn't fit well.
Old May 7, 2014 | 04:04 PM
cm60k's Avatar
Popey,
Do you mean you need a smaller star like 76mm or 78mm or 80mm...??
ZAYED,,
Old May 7, 2014 | 10:50 PM
popey24's Avatar
Original 80mm will fit fine, 75 is ok too. But 85 does not fit well. And it must be flat.
Old May 7, 2014 | 11:13 PM
cm60k's Avatar
As you mentioned; 75mm wheel cap is the best way, isn't..??
Name:  Wheel cap star.jpg
ZAYED,,
