C43 Heater Fan
Old Mar 15, 2014 | 12:38 PM
Maetar's Avatar
1998 C43 AMG
C43 Heater Fan
Greetings. 1998 C43 heater fan started acting up 1 month ago, wouldn't work when starting car until I hit a few bumps, then it worked. Now it never works. I checked 1 fuse under the hood and it's good.
Suggestions please? Thank you.
Old Mar 17, 2014 | 04:45 PM
Maetar's Avatar
1998 C43 AMG
Has this happened to anyone? Ideas?
Old Mar 18, 2014 | 12:22 AM
cm60k's Avatar
This fan motor got internal brushes & bearing, when one of these goes away, it will starts to hesitate,
you have to pull it out and check them, or you can get a new fan with motor assembly...
ZAYED,,
Old Mar 18, 2014 | 10:00 AM
Maetar's Avatar
1998 C43 AMG
Thanks for the information. Are the brushes easy to repair? How do you tell which ones are bad?
Old Mar 18, 2014 | 10:02 AM
Maetar's Avatar
1998 C43 AMG
Thanks for the information. Are the brushes easy to repair? How do you tell which ones are bad? Also any idea where to order new brushes and/or a whole new fan assembly?
Old Mar 18, 2014 | 10:31 AM
cm60k's Avatar
When blower works by hitting or pump it, means brushes are gone,
if blower shaking when its cold, means motor bearing goes away,
if it starts then stops with every "2-3" seconds, means motor armature die, which symptom you have..??
ZAYED,,
Old Mar 18, 2014 | 03:57 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Mine does this, but it also shows it on the climate control display. The black boxes that show fan speed will all suddenly be empty, and the fan isn't blowing. I can sometimes turn one of my blinkers on and the fan will come back on...?
My blinkers also intermittently work, but my wiper delay always works. Confused.
Old Mar 19, 2014 | 03:15 AM
DRBC43AMG's Avatar
Electrical jinks in there ;-)
