For those with c32 brakes. Need input.
Old Jul 17, 2014 | 12:16 PM
  #76
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
What do you guys think of this 20 degree swivel banjo fitting?
If you guys are interested, we can make them available to the correct length and include M10x1.0 banjo bolts.
Old Oct 17, 2014 | 03:48 PM
  #77
Pagz's Avatar
C43 w/clk55 Organs
Does the ML55 use the same piston sizes as C32/55?
I ask because the calliper mounts on the front of the disk for the ML, maybe we could use the piston housings but with calliper bracket from C32/55 as I suspect ML has different rotor offset?..
The ML's banjo is non-directional so much better for us...
Old Oct 17, 2014 | 04:23 PM
  #78
cm60k's Avatar
*ML55 using same C32/C55 Rotor dia., but in higher offset with non-drilled,
*it has a differ bracket size between bolts, unfortunate they NOT fit,
*Yes sure, ML55 using the same piston sizes with C32/C55,,
*i'm always using banjo hoses, it's easier to fit without circus twisting..
ZAYED,,
Old Oct 17, 2014 | 04:29 PM
  #79
Pagz's Avatar
C43 w/clk55 Organs
Thanks Zayed!,
Could it be possible to swap the piston housing's from ML to C32/55 bracket so offset is correct?...
Cheers,
Old Oct 17, 2014 | 04:40 PM
  #80
cm60k's Avatar
Sure Paul, piston's are swappable,,
seems you looking for pistons..?
ZAYED,,
Old Oct 17, 2014 | 07:18 PM
  #81
Pagz's Avatar
C43 w/clk55 Organs
That's good news!,
So this means you could theoretically make a Frankenstein caliper from the ML and C32/55 calipers that has correct piston orientation with bleed valve upwards and easy banjo attachment?
Zayed, do you think 340x30 "171 421 01 12" would work with C32/55 caliper?
Old Oct 17, 2014 | 10:33 PM
  #82
cm60k's Avatar
Yes Paul, this P030 340x30 Rotor will fit, i try it 3 years ago, but honestly; not remember if it need 4mm or 6mm washer to balance it with caliper..
ZAYED,,
Old Oct 17, 2014 | 11:47 PM
  #83
Pagz's Avatar
C43 w/clk55 Organs
Thanks Zayed
By chance did you weigh the P030 rotor?
Old Oct 18, 2014 | 12:07 AM
  #84
cm60k's Avatar
AnyTime Paul,
as i remember; 8.8 or 9kg, but not soo sure, my mind need a major service during age..
ZAYED,,
Old Oct 18, 2014 | 03:40 AM
  #85
Pagz's Avatar
C43 w/clk55 Organs
Thank you,it seem's fairly heavy!
Its ok I think we will all need a major service at some stage...
