Rear axle diff oil cooler?
Old Jun 15, 2014 | 06:01 AM
KJI3jflarryfe93's Avatar
This oil cooler for w203 C55AMG does it also fit C43 without heavy modifications?
Is it just plug n play?
Parts number is #A1713510108
Old Jun 15, 2014 | 06:40 AM
cm60k's Avatar
It's won't fit Dennis, need to fabricating bracket, done it before, but not that good fitment...
https://mbworld.org/forums/c36-amg-c...-almost-5.html
our friend "FranKW", bought a bracket for W203 diff., we need a good source for our W202...
https://mbworld.org/forums/c32-amg-c...pter-here.html
ZAYED,,
Old Jun 15, 2014 | 07:20 AM
ZAYED,,
hey bro
so i need to get a bracket made out of aluminium to fit the cooler fins onto my diff?
bracket you put on your car did you take it from a different MB model and customised it to fit it on your diff?
to make it extra special you could add a sensor to your diff with a VDO gauge showing the work temperature.
a guge like this
http://www.ebay.de/itm/VDO-VIEWLINE-...item1c41b754d2
Old Jun 15, 2014 | 11:28 AM
cm60k's Avatar
This is simple alloy primitive customize bracket, just to hold the cooler into the rear cover,,
*sensor is a good idea, prefer to put it in case of doing additional cooler/oil pump/hoses...
ZAYED,,
Old Jun 15, 2014 | 11:49 AM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
I have access to man with cnc machine...
Old Jun 15, 2014 | 01:06 PM
hey bro
maybe your compadre can make us a batch to keep the cost down if we make a group buy for an alloy bracket?
but you have to be the guinea pig to test the 1st bracket to see if it fits perfectly?
ask him if he is willing to help out?
Old Jun 15, 2014 | 01:59 PM
DRBC43AMG's Avatar
Nice idea people, but is it really necessary? The only time I would find it necessary would be if I tracked heavily, but then I would use a "real" car, like a Porsche for exemple. I would also need to have real temperature measurements to make.sure its necessary
DRBC43AMG's Avatar
Nice idea people, but is it really necessary? The only time I would find it necessary would be if I tracked heavily, but then I would use a "real" car, like a Porsche for exemple. I would also need to have real temperature measurements to make sure its necessary ;-)
Old Jun 16, 2014 | 12:44 AM
cm60k's Avatar
Prefer additional oil cooler over than air cooled, that will be PERFECT for Increasing lifetime of all diff. internals...
ZAYED,,
