C43 WIPER PROBLEM
Subscribe
Dec 16, 2014 | 01:11 PM
The wiper gets stuck and then stops working, what could cause this? The later it would start again.
here is the video: http://vid304.photobucket.com/albums...G/IMG_4453.mp4
Reply 0
Dec 16, 2014 | 01:40 PM
assembly needs white lithium grease?
Reply 0
Dec 16, 2014 | 01:47 PM
Quote: assembly needs white lithium grease?
I will try before my drive back that was the video from this morn...
Reply 0
Dec 16, 2014 | 03:21 PM
Same thing started happening to my C280 and I found these instructions on how to lubricate the wiper mechanism.
http://www.202tech.com/howto/wiper.html
Reply 0
Dec 16, 2014 | 03:30 PM
Quote: Same thing started happening to my C280 and I found these instructions on how to lubricate the wiper mechanism.
Reply 0
Dec 17, 2014 | 10:48 PM
Yup.. It needs greased same thing happened a few months back. Ended up doing the job in a car wash. should do this job every year or so depending on how much you use your wiper.
Reply 0
Dec 18, 2014 | 12:39 AM
Yes It happened to me this morning aswell. After a much needed rain from our SoCal drought, i turned on the wiper and noticed it was getting stuck. I going to grease it tomorrow for sure.
Reply 0
Dec 18, 2014 | 11:27 AM
We all seem to look elsewhere for answers to our technical problems and forget the sticky on the first page:https://mbworld.org/forums/c36-amg-c...deos-w202.html
Check out the second video of post #89. Everything is explained on there
Reply 0
Explore
Dec 19, 2014 | 09:26 AM
now if only someone could help me figure out how to fix the fact that the rest position on my black 98 is on the wrong side of the car...
Reply 0
Dec 19, 2014 | 09:58 AM
I tried, I could remove the head and replace the gasket on a 1960 Pontiac Ventura, but I can get this cover off the wiper arm if my life depended on it. I was able to spray some grease from under the arm into the main shaft.
I also noticed the rubber and the plastic cover under the wiper arm need to be replace and all those scratches at the bottom of the cover were already there...
C43 WIPER PROBLEM-img_4500.jpg   C43 WIPER PROBLEM-img_4499.jpg   C43 WIPER PROBLEM-img_4501.jpg
Reply 0
Dec 19, 2014 | 10:21 AM
Quote: I tried, I could remove the head and replace the gasket on a 1960 Pontiac Ventura, but I can get this cover off the wiper arm if my life depended on it. I was able to spray some grease from under the arm into the main shaft.
there are small clamps on both sides under the plastic cap, you need to put your fingers below and unhook the latches
Reply 0
Dec 19, 2014 | 10:53 AM
Easy indeed when you know the trick...
Reply 0
Jan 31, 2015 | 06:37 PM
Ok so this problem came back and came back with a vengeance. So at first after I greased it and finally learn how easy it was to open the covers. But on my trip to Eureka from LA I encountered a couple of storms at time at freezing temps. So suddenly the wiper motor stopped working. and I have to travel back without wiper which I didn't mind as I am used to driving in Europe where I grow up with the ****tiest cars you can think of.
My mechanic went through the whole wiper system and after checking it for an hr it gave me the bad news that I need a new motor. Since he was doing an oil change anyway he only charged me $15 to test the wiper and see if the motor was functioning without the wiper arm on.
So I called on our forum member Fred and he sold me an OEM motor for $40+$40 to install and we installed it this morning in a bit over an hr. Was a bit tricky to get the wiper in the same position so that it would extend at the right moment and place. But he did it and actually thought me how to do it.
We swapped the assembly and I retained the blade and ended up with the better of the two including an almost like-new round rubber seal under the wiper since mine was completely dry and destroyed.
I fell better doing this with a used OEM than buying an new aftermarket motor for $60.
Thanks Fred!
Reply 0
Subscribe
Currently Active Users (1)
