Need help with partsnumbers MB fluids
Old Mar 5, 2015 | 01:53 PM
KJI3jflarryfe93's Avatar
I apprechiate if someone can help me out with partsnumbers for some MB fluids as I can't find them.
I'm doing a B-service on my car this year.
I was thinking of replacing:
Transmission öl
Brake fluid
Diff öl
MB # partsnumber?
How many X liters of ATF transmission öl do I need for a replacement job and tranny flush?
MB # partsnumber?
How many X liters of brake fluid do I need?
MB # partsnumber?
How many X liters of diff öl is required for rear achle?
MB # partsnumber?
Bolt kit for: Engine mounts W211 E55AMG SuperCharger
# 220 240 27 17
Thanks for your help
Old Mar 5, 2015 | 05:04 PM
cm60k's Avatar
*1) Trans. oil:-
need 4 quarts with-out converter, #: "001 989 21 03/10", optional with 7-G-tronic oil #: "001 989 68 03/10"
i dont think you need to flush tranny, it's not necessary..!
*2) Brake oil:-
need 2-3 quarts, OEM or Bosch Dot-4 #: "000 989 08 07/13 "
*3) Diff oil:-
need 2 quarts, #: "001 989 17 03/10", optional with Castrol/LSD #: 001 989 52 03/10"
*4) E55K Engine mount kit:-
a) 2 bolts from mounting to Engine support #: "N 3040 17 010051"
b) 2 bolts from mounting to subframe #: "202 990 22 01"
ZAYED,,
Old Mar 6, 2015 | 06:28 AM
Originally Posted by cm60k
*1) Trans. oil:-
*2) Brake oil:-
*3) Diff oil:-
ZAYED,,
thanx bruther
i can always coun't on you with the right intel.
i am not familiar with US measuring fluid system as we use Litre in europe.
how much is 4 quarts of ATF öl in Litres?
Is that total amount of fluid for transmission including filling up the torqe converter?
how much is 2-3 quarts of brake fluid in Litres?
same goes for diff öl in Litres?
same L with brake fluid?
for E55K bolt kit, is it only bolts, no washers or nuts included?
thanks bro
Old Mar 6, 2015 | 07:19 AM
cm60k's Avatar
Anytime Dennis,
*quart & liter almost the same, 1 quart = 0.9xxxx liter,
*4 liters with-out converter, 8 liters with converter,
*almost 2 & half liter for brake, and 2 liter for diff. as well,,
*Yeah, only bolts for Engine mounts, no washers need it, but if old bolts fine no need to replace them..
ZAYED,,
Old Mar 6, 2015 | 10:23 AM
ok my brother
thanks for your expertise
Old Mar 6, 2015 | 04:24 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
you need 4 liter bottles for the trans but it should only take 3.5. If you don't have the dipstick, put in 3.5 and call it done.
Old Mar 6, 2015 | 04:38 PM
i'm draining my complete tranny, i want all new ATF oil in tranny incl TC.
this service needs 8 Litres of oil for tranny and TC?
bottles are they sold in 1Litre size?
Old Mar 6, 2015 | 08:07 PM
cm60k's Avatar
As i know; MB has 3 kind of ATF bottles according to Euro/japan markets,,
1 liter>1.5liter>>5 liter, not sure about U.S if they are the same..!
ZAYED,,
Old Mar 9, 2015 | 10:49 AM
benzslo's Avatar
They are 1 liter here.
Old Mar 9, 2015 | 12:24 PM
MarcusF's Avatar
2002 CLK430
For the brake flush, I use 1 liter of fluid. Before the US DOT decided dye was illegal, I alternated between ATE Blue and ATE TYP200 so I know 1 liter would flush all of it. Of course, that's with a W208 and a W204. A W202 may have a much large fluid capacity.
