adjusting throttle response?
I would bury the foot and the car feels like its slowly catching up with the pedal until it unleashes its power.
Compared to my friends w202 c55, my car is really slow. Its been a lot faster before for sure.
Im thinking its the throttle response sensor or maybe I need to adjust the throttle cable. The problem is I dont know much about adjusting this stuff but from what I read it sounds like it could be related to that.
Can someone enlighten me or point me towards some info on adjusting throttle cable, when and why it should or should not be done.
Thanks in advance
so we should expect that this part might eventually fail on all our cars in the future if it didn't broke down yet?
edit: or it's just another one, because here's what pelicanparts has for the number you gave, and it's same price and same part as the one I listed earlier: http://www.pelicanparts.com/cgi-bin/...sor)%2520%2520
I noticed while at idle and i rev the car, it sounds kinda weird as the revs are coming down. It comes from the area where secondary cats are.
Would an exhaust leak cause these symptoms?
Anyone know if ill still pass SMOG in case i have to remove secondary cats?
maybe you have a leak somewhere causing you troubles.
buying used engines without replacing certain parts if they are worn out, you will have a bad performance engine.
did you check codes?
why don't you take your car to your MB mechanic buddy who did the job and tell him your issues, he can surely help you out.
This is an issue thats kind of always been there on and off.
I think i might have found the problem. Too bad i didnt know about this before i changed the tranny fluid.
Read this. I have same symptoms and my tranny shifts from first to second kinda hard. It jerks the car.
http://www.benzworld.org/forums/w210...1423078?page=1
I really dont k ow what to look at next. I heard it could be the modulator valve but i dont even know where to find one.
I posted in the w210 section for info since i have a tranny from a 2001 e55 but no luck.
adjusting the bowden cable doesnt seem to make any difference
Any ideas?
