I've been thinking of getting Evosport pullies for my C43 and then a performance chip.
Did anyone try the pullies? Any noticeable gains?
Get the pulleys from EVO. I got my chip from another source. Comparing my bone stock C43 with my modded C43, there is a huge difference across the power band. Modded is so much quicker....
what is the diameter of your evosport alternator pulley? i just bought a c43 and the previous owner claims to have put the pullies on but they appear to be OEM.
Quote:
Mind sharing the place you get the chip? How much HP do they add?Originally Posted by fastneutron
Can the pulley be easily installed? Or the workshop would be the best place?
I was looking at where those pulleys are... they look pretty concealed..
Quote:
Do you have before and after dynos?Originally Posted by fastneutron
pulleys are a very easy install, the belt puts just enough tension on the pulleys so you can loosen the bolts and the belt tensioner easily detensions the belt for removal, nice quick and easy mod.
Quote:
Watch out for the power steering pulley. That mamma took awhile with WD40Originally Posted by sgort
and a puller. The others were easy (less than 5 minutes each). Great mod....
ExploreCurrently Active Users (1)
