car died on highway..
Old Dec 17, 2016 | 02:27 PM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
You can generally hear a fuel pump prime right before you start the car. Grab a friend, get as close to the fuel pump as you can get, and have the friend turn the key to on (but don't start) and listen for the pump to prime. If it primes, you at least know the relay is working. You can also test the relay out of the car with a multi-meter and some jumper wires.
Old Dec 17, 2016 | 02:29 PM
cm60k's Avatar
Is the car starting properly before replace C280 Relay..?,,
and is there a little Engine shacking with or without acceleration..??
"ZAYED"
Old Dec 17, 2016 | 06:44 PM
PJmak's Avatar
The car doesnt start with either of the two relays. Giving it gas while cranking doesnt do a thing
Old Dec 17, 2016 | 07:21 PM
cm60k's Avatar
Is there an Electric current to the fuel pump..?,,
do you hear whistle sound when you open the key to position 2..??
"ZAYED"
Old Dec 17, 2016 | 09:06 PM
PJmak's Avatar
Ill look for the sound. Not sure how to check the current.
I already have the spare pump taken off and ready to gonon the car. It would be nice if I didnt have to replace it tho
Old Dec 17, 2016 | 09:17 PM
ECTurboGSX's Avatar
Process for testing for fuel pressure should be pretty similar to this video. You can get a loaner kit from AutoZone for the gauge.
Also, you don't need to start the car like he does in the video. Just need to turn it to run and the pump should prime the system to about 40 psi or so.
Old Dec 17, 2016 | 10:59 PM
  #32
cm60k's Avatar
You can use "Multimeter" to check the current in fuel Relay, and unplug the fuel pump connector & test if there are Electricity in connector pins,,
or at a simple way; you can use bulb with wires to see if there are Electricity when you put the key in position 2..
"ZAYED"
Old Dec 18, 2016 | 12:52 PM
  #33
PJmak's Avatar
https://www.youtube.com/watch?v=6lBowLTZ2KE
Thanks man. Ill see if I can rent the tool from a local store and do it that way.
Old Dec 19, 2016 | 11:51 PM
  #34
PJmak's Avatar
Replaced the fuel pump but no go.
What else can cause multiple missfires while driving and make the engine die down?
Old Dec 20, 2016 | 01:03 AM
  #35
cm60k's Avatar
Did you diagnose the car after fuel pump replaced..?,
try to pull out the air box & check all air/ breather hoses, if everything's OK, then
"MAF/CPS" are the remaining things to watch out..!
"ZAYED"
Old Dec 20, 2016 | 10:36 AM
  #36
PJmak's Avatar
Ill do that today thanks man. I peeked at the front breather hoses but not the back ones
Old Dec 20, 2016 | 10:43 AM
  #37
mickey13's Avatar
1999 AMG C43
Shot in the dark here but maybe battery/alternator? Did you pick up a multimeter to test voltage? Battery might not have enough juice. They are pretty cheap and a great tool.
Old Dec 20, 2016 | 10:50 AM
  #38
PJmak's Avatar
Battery should be fine.
Keep in mind the car died while driving
My brother has a multimeter so ill test a few things today.
Old Dec 20, 2016 | 05:55 PM
  #39
zynko's Avatar
84 E24 M635CSi / 95 W202 C36
I've seen this happen before and the likely culprit is the voltage regulator, if the brushes are worn out, the alternator will not send the right voltage to the ECU causing all sorts of malfunctions. Main problem is the engine dies while driving and won't start again.
To fix it, you need to remove the alternator to access the back of it, remove the black plastic cover and replace the voltage regulator being careful not to damage it during installation. There are two indented grooves in the shaft of the alternator for the brushes to align and make contact.
Hopefully this will help get you on the road again.
Old Dec 20, 2016 | 06:14 PM
  #40
PJmak's Avatar
Thanks for input.
any other symptoms that I can look for in order to establish if its that?
​​​​​​​I did notice the dashboard sort of flickering while the car is attempting to start. Maybe I was just seeing things
Old Dec 20, 2016 | 09:48 PM
  #41
zynko's Avatar
Low battery, flickering dash warning lights, sudden shut off while driving...
The way u describe it leads to the worn out brushes, intermittent contact could cause the dash to flicker although no CEL. You have been hunting for the cause of a no start with other components that probably were Ok but the ECU is not getting enough power for all the systems to initialize a normal start-up.
From the 70's thru 2000's this is a common failure point. This is a $30 dollar part, at worst you eliminated another point of failure and move on to more expensive parts.
Old Dec 20, 2016 | 10:15 PM
  #42
PJmak's Avatar
So just took my alternator off and this is what I have.
There are shreds from the old belt in there from when it dnapped one me way back.
Im not sure what the condition of this part is....is it still good?
Im getting a spare tommorow and ill see how it goes.
Attached Thumbnails car died on highway..-20161220_183840.jpg   car died on highway..-20161220_183820.jpg   car died on highway..-20161220_183814.jpg
Old Dec 20, 2016 | 10:17 PM
  #43
PJmak's Avatar
One more. It was making contact with the middle copper part and the alternator was spins freely.
I think ill change the whole thing
Old Dec 20, 2016 | 11:20 PM
  #44
zynko's Avatar
Down to the last 1/3 is usually when it starts to fail, the springs behind it are weak, loosing contact with continuous vibration. U should have 2/3 more than that with the new voltage regulator.
Old Dec 20, 2016 | 11:30 PM
  #45
cm60k's Avatar
Looks like half age of this Regulator..!,,
if you gonna replace the alternator assembly, recommend to go with (180A) from 55K's, it's more reliable with better Regulator..
"ZAYED"
Old Dec 20, 2016 | 11:44 PM
  #46
PJmak's Avatar
Got a spare one from my 99 c43 parts car. It has less than 70k so hopefully its still good. The car ran fine when it was in one piece this year
Old Dec 20, 2016 | 11:45 PM
  #47
PJmak's Avatar
https://youtu.be/uQP8gu_HVd0?t=2m18s
Thanks. I like watching that guy....ill check out this vid
Old Dec 21, 2016 | 09:41 PM
  #48
m00nsh0t's Avatar
black w202 C43 / Black e93 328i / Smoke Silver 560SEL
That alternator looks pretty knackered to me, and the symptoms you describe sound like some form of alternator related f*ckery.
Old Dec 21, 2016 | 09:47 PM
  #49
PJmak's Avatar
Yep hopefully.
Got the one off my parts car...looks almost new.
Old Dec 21, 2016 | 10:16 PM
  #50
sick430's Avatar
CLK Cabrio
yeah that one looks great! hope this fixes your problem.
