car died on highway..
Old Dec 26, 2016 | 12:52 PM
  #76
PJmak's Avatar
Originally Posted by justinwrock
Hey PJ - long time, no talk. White could be residue from evaporated water... (have you ever pressure washed your engine and/or had a coolant leak?)
If needed, I have a set of etorx, spare CPS, and an SDS... Any/all is at your disposal if you need it.
Hey man long time for sure.
I got all spare parts from my c43 parts car. Im hoping the issue is not serious and Ill eventually find it. Im going over to my brothers today to grab a multimeter and some more tools....I should be good.
Whats new with you? How have you been?
Old Dec 26, 2016 | 12:53 PM
  #77
PJmak's Avatar
Never pressure washed my engine btw.
If I cant figure it out soon I might take you up on that SDS offer
Old Dec 26, 2016 | 01:50 PM
  #78
cm60k's Avatar
Originally Posted by PJmak
Yea it sounds like it wants to but it just cant
No any cranks sound..?
;ZAYED;
Old Dec 26, 2016 | 03:57 PM
  #79
PJmak's Avatar
Theres sound it just wont start
Old Dec 26, 2016 | 04:46 PM
  #80
cm60k's Avatar
I see,
i think CPS/Cam sensor or fuel are the only things left..!!
;ZAYED;
Old Dec 26, 2016 | 06:52 PM
  #81
PJmak's Avatar
Got a multimeter and I wanna test the coils but cant find any instructions. Any helpnis apreciated
Old Dec 26, 2016 | 08:23 PM
  #82
zynko's Avatar
84 E24 M635CSi / 95 W202 C36
This is a generic diagnostic and testing instructions but it does go into depth on what can cause it. Hope it helps solving your problem!
http://www.aa1car.com/library/ignition_coils.htm
Old Dec 27, 2016 | 12:20 PM
  #83
PJmak's Avatar
Btw I stripped the cps screw :/ its gonna be a challenge to get that thing out.
Old Dec 27, 2016 | 12:43 PM
  #84
mickey13's Avatar
1999 AMG C43
i would hit it with some bolt penetrator and then bang the next size on it
F%@&!!!
Old Dec 27, 2016 | 12:59 PM
  #85
PJmak's Avatar
Ill see if I can get oneof those extractor sockets kits somewhere today.
Ifs in such a tight spot so. Im hoping the sensor will slide out easy too
Old Dec 27, 2016 | 02:24 PM
  #86
tdpthagenius's Avatar
MB E550 Coupe
Let us know if changing out the cps worked...something similar happened to me about a month ago but, I cut the car off and it started back up again with no issues...left it parked about 2 hours, no issues...went to start it up a week later and it would not crank and all power was slowly being lost in the car...i finally got a new battery yesterday, got it installed, and it started up like new...i never knew of a car falling dead while sitting at a light because of a battery...yet and still my mom's e350 would not turn over after her coming out of the store for 5 minutes and it was her battery...also fwiw, my check engine has been on for quite some time saying codes p0171 and 0174 right after having to replace my throttle...i am going to get another diagnostic on the CEL before replacing the MAF as I think it is...the screen is quite blackish when I removed the cover...
Old Dec 27, 2016 | 02:28 PM
  #87
PJmak's Avatar
Ill definetly let you know.
I have a 2000 c280 also and I swapped my battery with that car and still no go.
The c43 batt measures 11.4x volts while the c280 measures 12.4x
Old Dec 27, 2016 | 02:58 PM
  #88
cm60k's Avatar
Generally;-
If meter reading lower than (13.2v>>12.8v), it may have bad battery DIN starting core or engine idle is too low for the alternator to put out sufficient voltage,,
that will directly affect to the power of the DIN starting in the battery, to provide enough power to the starter solenoid..!
*prefer to check the CPS first, then see about the battery voltage..
;ZAYED;
Old Dec 28, 2016 | 06:03 AM
  #89
DRBC43AMG's Avatar
That's going to be a tough job. As you say space is super tight back there. You need to drill into the torx recess head say around 5mm, before getting a extractor bit inside (if space allows). I don't know if it is possible to get to the screw from under the vehicle and use a mole grip to unscrew. If that doesn't work, maybe you need to "destroy" the CPS housing and surround with a metal chisel which may give you better access to the torx screw.
I learned the hard way that torx headed screws are a real b*tch to work with and you need to use superior brands torx sockets only. The cheaper versions are just slightly undersized and bugger the screws big time placing you in a problem spot.
I hope you don't need to pull the engine to repair that CPS.....
Old Dec 28, 2016 | 10:32 AM
  #90
PJmak's Avatar
Worst case the intake manifold and all the stuff behind it will have to come off which is not that bad.
I had taken off all of that in my parts car and the access to the cps was much much better.
I took a day off yesterday and did nothing so no progress.
I just hope nothing went wrong with the motor. I need to know before I start throwing money at it.
Old Dec 28, 2016 | 10:41 AM
  #91
cm60k's Avatar
Did you diagnose the car after CPS been replaced..?, any codes..??
;ZAYED;
Old Dec 28, 2016 | 11:18 AM
  #92
PJmak's Avatar
I havent done it yet man
Hopefully ill get to do it today
Old Dec 28, 2016 | 11:28 AM
  #93
KJI3jflarryfe93's Avatar
could have saved you some time and cussing if you had asked a majstor buddy to help you out with your car.
you did check most of the stuff and problems still there.
hobby mechanics can do some stuff, more difficult jobs should be done by professionals.
I hope it's a quick and cheap fix for ya!
Old Dec 28, 2016 | 11:30 AM
  #94
PJmak's Avatar
One thing to point out.
With the original battery while turning the key over sometimes the car would sound as if its out of electricity. It does that quick *blip* as if tje battery is dead.
However it doesnt do it all the time. Swapping batteries gets rid of that and the car sounds like it wants to start but it still cant
Old Dec 28, 2016 | 11:31 AM
  #95
PJmak's Avatar
Its all good haha. If I have the garage and tools I enjoy working on the car. I just moved into a place with a garage so I can slowly troubleshoot and do one thing at a time
Old Dec 28, 2016 | 11:40 AM
  #96
it ain't fun when problems creepin' up on ya.
small prob here, a bigger prob there, keeps going on and on..........
do you hear fuel pump buzzing when you turn on ignition?
your prob is not fuel related?
did you check all your osiguraci, no-one being fried?
sometimes a problem could only be a tiny glitch somewhere not giving juice on start up??
Old Dec 28, 2016 | 12:21 PM
  #97
PJmak's Avatar
Fuel pump does make a sound. I already cleaned the fuel injectors. Fuel filter doesnt have too much mileage in it so that should be ok.
Im narrowing it down to either a cps, coil/plug/wire issue or vacum leak somewhere.
If all that fails then im removing the whole exhaust and replacingit with the one from my parts car.
Old Dec 28, 2016 | 01:07 PM
  #98
oh boze moj, you seem to have lots of work ahead!
did you check your ignition?
your ignition module EIS might be worn not giving kontakt to your key on start up
this part is expensive
Old Dec 28, 2016 | 01:29 PM
  #99
PJmak's Avatar
Would that cause the car to die while driving?
Remember the issue occured while the car was running and the result is multiple missfires. Wether its preventive missfire or real missfires I dont know yet
Old Dec 28, 2016 | 01:50 PM
  #100
i don't know if your car died related to bad key and if you have a worn ignition?
you have to rule out everything to find your problem.
your car doesn't krank now, it only gets power on ignition.
you did get a new chrome key from stealership am I right?
new chrome key does NOT always work properly with your ignition if ignition is worn!?!?
kar won't always krank with new chrome key if ignition is worn!
you have to remove key, insert key again then try to start, sometimes you have to repeat procedure 2-3 times for kar to krank by inserting key and removing key if kar doesn't start on 1st try.
the old style key works much better wheter or not EIS is worn, here the new chrome key pusi kurac compared to old key in funktionality!
did you try to start your car with the old style key?
if you can't find the problem, ask for help from your best majstor buddy, if you still have problems put your car on a trailer take it to a specialist
