Airfilters
Old Mar 14, 2017 | 04:25 AM
mickey13's Avatar
1999 AMG C43
Airfilters
Did we ever find fast-flow filters or is everyone just sticking with OEM.
K&N=bad?
Old Mar 14, 2017 | 04:38 AM
DRBC43AMG's Avatar
K&N=bad?
This is a long going debate.... with plenty of pros and cons.
I have had fast flow filters both K&N and now Green for years on nearly all my vehicles with never a problem. The secret is to apply a very thin spray of oil after having cleaned them. Over oiling will indeed kill the MAF. Clean them at least x1 year regardless of distance driven. If you live in a sandy desert type area, then a more regular cleaning would be a good idea.
The OEM filters do the job perfectly but the fast flow ones will give you a touch more intake noise. With the big air-box it is very much more noticeable
Old Mar 14, 2017 | 05:12 AM
mickey13's Avatar
1999 AMG C43
Always very jealous of your big box, you got the bigger 4" right?
Old Mar 14, 2017 | 05:54 AM
cm60k's Avatar
IMO;-
not recommended to go with oily filters,
we have very sensitive MAF film, that will affected during hot oil sneaks there,,
moreover; when oil mixed with dust & Humidity, the vent rooms will clogged, that will definitely causes bad reflect to the air inlet & density..!!?!?!
-;ZAYED;-
Old Mar 14, 2017 | 09:35 AM
W202AMG's Avatar
W202 C43 1999
And that is all theyll give you.
There is no power advantage, however there is a disadvantage in that the filtering is not as fine, and dust will go through.
The K&N is fine for a pre-filter ( not that youd use one on a road car ) , but there is no need for it as a primary filter.
Old Mar 14, 2017 | 02:53 PM
DRBC43AMG's Avatar
It's 8cm thick at the air-box exit over the MAF. So that's 3.1496 inches so it's not the 4" one. It could be that the 4" we here was a prototype and a bit too high to fit without rubbing. I believe George cleared this question when answering one of Kowalski's multiple queries...
Old Mar 14, 2017 | 03:07 PM
eFifty5AMG's Avatar
2004 E55
aFe 31-10084 filters in a custom airbox/no maf mesh at all, not one issue.
Old Mar 14, 2017 | 04:16 PM
PJmak's Avatar
I have a set of used(very good shape) K&N filters that I dont need. Shoot me an offer if you want them
Old Mar 15, 2017 | 12:22 AM
Dziner82's Avatar
99 C43 AMG, 2001 CLK55 AMG
i have K&N filters in my C43 and CLK55. been 4 years in the C43 now, and cleaned 2x i think, no issues at all. only 1 year in the CLK55, haven't cleaned yet (i only drive the cars in the warm season and 5000 miles or less a year so not much use.
i have no idea how people have problems with K&N, im guessing a few people just greatly over oiled them when cleaning??
Old Mar 15, 2017 | 03:43 AM
DRBC43AMG's Avatar
Exact!
Old Mar 15, 2017 | 04:32 AM
W202AMG's Avatar
W202 C43 1999
No, the issue with them is they do not filter as fine as paper filters.
Old Mar 15, 2017 | 05:39 AM
DRBC43AMG's Avatar
Yeah, I guess if you live in a very dry and dusty area, the use of OEM filters might be preferable for optimum air filtration.
Old Mar 15, 2017 | 08:48 AM
cm60k's Avatar
+10000000000
-;ZAYED;-
Old Mar 15, 2017 | 12:29 PM
speed43's Avatar
1999 C43 Amg
All my modded air boxes are about the same size. Maybe 1/4 inch difference from each one. I only made ONE lower than the rest. I have a version 2 air box now. Made the first one for pjmack which he should receive today or tomorrow.
Old Mar 15, 2017 | 07:56 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
Oiled filters kill the maf period, can't tell you how many I've replaced with k&n filters.
Old Mar 15, 2017 | 08:07 PM
eFifty5AMG's Avatar
2004 E55
Trust benzslo. I keep hearing oil is the enemy.. that is why I chose the aFe Pro Dry S filters. Mann or aFe for me- No oil no problems.
Old Mar 15, 2017 | 11:40 PM
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG/2021 Toyota Tundra Crew Max TRD Sport Premium
K&N=bad?
I'm running Green Filters and I couldn't be any happier.
Old Mar 16, 2017 | 12:42 AM
DRBC43AMG's Avatar
Like me
Old Mar 16, 2017 | 01:55 PM
nkctb7's Avatar
Like me
Old Mar 16, 2017 | 03:13 PM
benzslo's Avatar
I run those afe filters also, pretty good alternative to stock replacement.
Old Mar 16, 2017 | 07:48 PM
mickey13's Avatar
1999 AMG C43
so if i want to steer clear of oil, looks like oem, afe or green? any other options out there?
Old Mar 16, 2017 | 07:55 PM
eFifty5AMG's Avatar
2004 E55
Green filters use oil. I think aFe & Mann are your only oil-free solutions.
Old Mar 16, 2017 | 10:59 PM
nkctb7's Avatar
Green Filters=Nothing like heavily oiled K&N and won't set off maf
• What makes Green Filter oil different from other brands?
Green High Performance Air Filters come pretreated with a specially formulated dirt-trapping oil. Our proprietary lightweight, synthetic Green Filter oil is designed to not damage any vehicle sensors.
This oil creates a positive (+) magnetic charge, or ionic bond, with the filter's stainless steel mesh. The positive charge attracts the negatively (-) charged dust particles entering the filter, causing them to cling to the steel mesh and allowing the cotton to remain clear for maximum air flow.
Green Filter oil also contains a swelling additive for the cotton filtration media. This causes the cotton fibers to swell, which allows the filtration media to collect the very small dirt particles (down to 5 microns) that could otherwise harm your engine.
Old Mar 16, 2017 | 11:02 PM
eFifty5AMG's Avatar
2004 E55
Green Filters=No oil.
http://www.greenfilterusa.com/filter...aintenance.php
Old Mar 16, 2017 | 11:11 PM
nkctb7's Avatar
My bad! I did correct it before you quoted me. Oil is so light it appears oil less!
