A/C diagnostic mode values for pressure?
Old Apr 7, 2017 | 04:52 AM
W202AMG's Avatar
W202 C43 1999
Hi all,
What sort of values should i expect to see on #7 when in diagnostic mode?
While sitting at idle for a couple minutes i see around 26°5ish, and while driving on the highway it was down around 7°2ish and a bit lower.
I would have to assume this value is in kPa.
Thanks all
Old Apr 7, 2017 | 08:42 AM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
If the AC is running, the pressure will fluctuate. The compressor will build up pressure and release it. That's how it cools. Ever used one of those air horn cans? It's under high pressure. As you press the horn button, it releases pressure and causes it to become very cold in your hand. The colder it gets, the less it performs. And obviously the lower the pressure the less cold it can achieve.
An AC system is just a way to recycle that stuff back into the can to build up pressure to a certain point so that it can release and cycle back around and repeat.
With engine running and AC on, you should see that number fluctuate slowly between 2 different points. 26.5bar seems awfully high, but I can't remember the spec.
Old Apr 7, 2017 | 09:05 AM
W202AMG's Avatar
W202 C43 1999
Yes i know how A/C works, i am an electrical fitter/mechanic by trade and spent over 17 years in the game, but looking to see what values should be expected on this set up
It is certainly not giving a reading in bar, if it is metric, which id say it is, the reading will be kPa.
26.5 bar is almost 385 psi, and you will never see that on the low side. 265kPa is 38ish psi.
Old Apr 7, 2017 | 10:59 AM
Sulaco's Avatar
ok, great. I just try to be blunt, when I started trying to figure out my AC woes I had to learn how the system worked (and a LOT of people have no idea how they work, they just ask "why isn't it working???").
so, sorry if that came across wrong.
I had no idea they measured in kPa over there, since they measure in bar here (but nothing else here is measured in bar, so I thought it was just what MB did world-wide)
But if it IS measuring in bar, then would that mean the pressure sensor is faulty? yeah, 385 would pop the evaporator in a heartbeat.
if it has the little "o" between the 26 and the 5, then its trying to say 26.5, if there's no little "o" it is trying to tell you 265, so maybe that's helpful?
Old Apr 7, 2017 | 12:58 PM
vinceC's Avatar
2014 ML350 4Matic
26 is way too high for compressor discharge (high side) pressure. I seems like you are not getting enough air flow through the condenser when at a stop. Typically what I expect to see is 6-8 when moving and a steady rise to 14-17 at a stop on a warm day.
This can count as a response to your question about the aux fans - they should be running at a stop when your high side pressure is this high. The pressure switch on the receiver/filter should be calling for the fans to run in your case.
Old Apr 7, 2017 | 08:04 PM
W202AMG's Avatar
W202 C43 1999
Are you saying that the reading given by #7 on the A/C display is the high pressure side? I read somewhere else that it was the low side, hence why i thought it mustve been in kPa.
Should the receiver/dryer be hot or cold during operation? On Corvettes it would get ice cold, but the whole setup is different to this car.
Old Apr 7, 2017 | 08:18 PM
W202AMG's Avatar
W202 C43 1999
At what pressure should the fans cut in?
Old Apr 7, 2017 | 08:30 PM
W202AMG's Avatar
W202 C43 1999
And where will i find the relay/controller for these fans?
The compressor cuts off at 30°0 on the display, and fans did not cut in.
Old Apr 7, 2017 | 09:34 PM
W202AMG's Avatar
W202 C43 1999
Some part numbers i need confirmation on:
Receiver: 2028300283
Pressure sensor: 1408300072
Are these the correct part numbers?
Old Apr 7, 2017 | 10:06 PM
vinceC's Avatar
2014 ML350 4Matic
#7 is refrigerant pressure in BAR, so high side.
I don't have cut in pressures for the later cars handy at this time. The early cars (with the dual aux fans like the C43) have two relays mounted in the relay/fuse box in the engine compartment (K9/1 and K10). The relays have a fuse on top. If your car is similarly equipped check the fuses.
These following values for the older cars but I think yours is similar.
The aux fan switch points for refrigerant pressure are (in BAR) = 1st stage 16 on, 13 off. 2nd stage 20 on, 17 off.
The switch points for engine temp (ECT sensor (B10/8) are (in degC) = 1st stage 100 on, 95 off. 2nd stage 115 on, 107 off.
In case you don't know, the fans have two stages - high and low.
The receiver is on the liquid side of the system (high side). It will be warm. I don't know about Corvettes. Placing the receiver on the low side serves no purpose so I don't know why anyone would do that.
Old Apr 7, 2017 | 10:14 PM
W202AMG's Avatar
W202 C43 1999
Thanks mate, so they are over with the main fuses under the bonnet? One cover lifts off and the second part is held by screws? Is this the one youre refering to?
Old Apr 8, 2017 | 06:15 AM
vinceC's Avatar
2014 ML350 4Matic
Yes - if the C43 setup is the same as the early 202s. No guarantee that is the case.
Old Apr 8, 2017 | 06:52 AM
DRBC43AMG's Avatar
Confirm there are relays under the second box lid in the rear. Easy to get to if you open the hood 90°
Attached Thumbnails A/C diagnostic mode values for pressure?-2016-12-15-15.37.27-615-dsc_1390.jpg   A/C diagnostic mode values for pressure?-2016-12-15-15.37.41-800-dsc_1391.jpg
Old Apr 8, 2017 | 06:56 AM
W202AMG's Avatar
W202 C43 1999
Checked all those today, all fine. Fuses are fine. Fans both run with power applied directly.
Must be the variable speed drive in the left front bumper.
Old Apr 8, 2017 | 07:00 AM
DRBC43AMG's Avatar
I had this document in my files
File Type: pdf
Old Apr 8, 2017 | 07:01 AM
W202AMG's Avatar
W202 C43 1999
Thanks mate
