Valve cover gaskets
Just use permatex right stuff and will last much much longer. Have your mechanic put a small amount on top and bottom of the rubber gasket and that's it.
I use this stuff to seal the half part of intake manifold and I've never have any vacuum leaks. This sealant is VERY good. Just make sure to let it dry as many hours as possible before driving. I once did a car with this and had to drive out after half an hour and no leaks to this day and it's been close to 2 1/2 years. But if I could let it dry for hours I would.
Don't let your machanic convince you that you shouldn't use a sealer. IF your valve covers are really warped this will fix that. It's that good!
https://www.amazon.com/Permatex-25224-Right-Stuff-Gasket/dp/B000HBM4FQ
As Speed43 says a good quality sealant is a must and if done correctly should last as long as the engine does
Did mine on both sides top and bottom in 2012. No problems since.
https://mercedessource.com/store/m11...s-demand-video
do we have anyone with WIS who can show in what order to tighten first bolt then go to bolt no.2 then bolt no.3 etc. etc.?
there's a thread on C63 forum, these valve covers have 13 bolts or so?
someone posted the tightening steps for valve cover bolts.
I can't find them for C43.
need a WIS sketch for C43.
http://www.benzworld.org/forums/show....php?t=2273162
according to Benzworldlink,
seems like there are different lengths for valve cover bolts, it's easy to screw the wrong bolt length to wrong place
torque is 9NM according to MB.
yeah, that's a good idea cutting out a V-cover stencil from cardboard paper then punching each bolt in the right place.
the only issue is to tighten correct bolt first, then go with the other ones in correct order
see bolt tightening for C63 the first reply
.https://mbworld.org/forums/c63-amg-w...l-leaking.html
we need a WIS stickie for C43
ProjectC55 mentioned in his previous reply when everything is cleaned properly, new gasket is fitted then put V-C back to it's place.
The first round when tightening each and every bolt, is to tighten each bolt with 4NM.
The 2nd round to tighten each and every bolt with 8NM.
WIS says 9NM.
I only want to re-tighten my bolts not doing any replace for V-C gasket.
These engines with age or mileage builds up will eventually weep their own pants.
How much torque do these bolts handle before they snap?
If you have bad luck to snap one bolt , then a helicoil is necessary.
WIS says 9NM.
I want to tighten this bolt, therefore wudd be good to know the bolting order from first to last for futura references if I discover more leaks.
there shudd be a sticky DIY for this VC job, everyone will experience this problem sooner or later.
If we have a sticky thread then we all know the procedure of cleaning, replacing and refitting everything back 2gether.
there are no sticky DYI threads for our C43.
ain't it better using Loctite in bolt threads, screws won't loosen up again?
how many spanner turns do these bolts handle with a torque wrench?
bolts will eventually snap messing with them too much?
The valve covers have a "spacer" cast into them at each bolt location. That ensures that the correct gasket crush takes place. Once the bolts are torqued correctly the "spacers" will be in contact with the head. No amount of overtightening will add crush to the gasket. If they leak they need to be replaced. See the photo.
