Issue w/ headlight switch
The headlight switch on my ‘95 C36 is acting up. I cannot get it to stay in the position that keeps the fog lights on.
Has anyone else experienced this issue? I’m not sure if I need to replace the switch or if there is a fix for it?? Any insight would be appreciated!
Cheers,
Rob
Cheers,
Rob
i ha e a spare switch from a c43 if you end up needing one
This is a first for me, I owned a few MBs from this era in the past. I’m pretty sure the switch will need to be replaced. I was curious if any of you guys experienced this problem in the past; it appears not so far. My safety inspection is due next month and would most likely fail because of this. The annual safety inspections in NOVA makes one realize how the time flies!!
Cheers,
Rob
http://www.benzworld.org/forums/w202...t-staying.html
I’m unsure if I can source the plastic seal, but I plan on taking the switch apart to see if I can maybe work some magic on it. I appreciate the help!
Cheers,
Rob
I have 1 taillight on my car that is shorted out somewhere. I thought it might have been the headlight switch. I picked up one from a yard for 15. It wasn't the switch. New ones are cheap too. PJ said he had one for you.
I'd even send you the one I have for free if I knew where it was but I'm sure PJ will let you have his for a few bucks.
Thanks again,
Rob
The inspection is due in Jan, but the car is ok in my driveway even if the sticker expires. I plan on replacing it in the next week or two. Don’t worry about the switch! I appreciate the offer, I plan to order one off eBay. Thx!!
Thanks man
If wer talking about the headlight switch, they are kinda hard to remove. Mine is in perfect shape and has less than 70k on it.
OP, If you dont have luck finding one let me know
