Throttle body upgrade
Old Apr 5, 2018 | 08:53 PM
blackbenzz's Avatar
haters crazy
Has anyone gone from the circular throttle body connector to the newer rectangular one? They are both 6 pin so maybe it can be done. Will give it a try but has anyone done it? Would make it easier
Old Apr 6, 2018 | 08:03 AM
cm60k's Avatar
Hey bro.,
To go with late model square TB plug, will need to replace:-
"ECU with EIS & Ign. lock /TCU/Engine harness/gear shifter +/-"..
-;ZAYED;-
Old Apr 6, 2018 | 08:55 AM
blackbenzz's Avatar
haters crazy
Originally Posted by cm60k
Hey bro.,
-;ZAYED;-
Thanks Zayed. Why can't you just rewire the throttle body?
Old Apr 6, 2018 | 09:19 AM
cm60k's Avatar
If i'm not mistaken;
new TB is fully Electric. controlled, but the old style comes with spring (as mechanical) side,
and each TBs got a differ ECU setup control, also DAS fire up is different due to the TCU file & wiring schematic..!
-;ZAYED;-
Old Apr 6, 2018 | 06:07 PM
blackbenzz's Avatar
haters crazy
-;ZAYED;-
Have you tried it? I'm going to
Old Apr 7, 2018 | 09:57 AM
cm60k's Avatar
I didn't try that, it could be work, but really can't assure that..!?!,
i swapped everything from 01 "W210 E55" ME2.8 into 98 "W202 C43" ME 2.0,
really was pain job,,
changed many things:-
"ECU/TCU/Engine harness/body harness/lateral sensors/injectors/brake pressure sensor/gear shifter +/-"..
-;ZAYED;-
Old Apr 9, 2018 | 10:58 AM
brad_c43's Avatar
'99 C43, '88 560SL
Very interested to get as much performance n/a as i can get from my c43, @blackbenzz let me know if I can help.
Old Apr 9, 2018 | 09:35 PM
speed43's Avatar
1999 C43 Amg
Raise the stock box by 2 inches.
Port the maf plastic housing.
Remove flaps of the plastic elbow.
​​​​​​Port both sides of the throttle body.
Port the manifold intake opening to throttle body.
​​​​​​Step on gas and say bye bye to any stock C43 and other cars. Want more power, put these things to a 5.4 engine.
Old Apr 15, 2018 | 10:59 PM
g60wall's Avatar
2014 E63s
Has anyone upgraded to a bigger MAF?
