Differential Bushings
when removed the bushing seems to go right through to the other side to the diff.
Anyone have or read a how to on these bushings?
I also need to replace the engine oil gasket because of a small oil leak. Can find this gasket anywhere. Anyone have a part number and good place to buy?
Thank in advance.
Picture of the diff bushings.
Theres a third bushing on the top thats easier to replace. You want to do that one as well
I need to do this on my car, I have a set of bushings thats new just laying around. Its a miserable job without the tool, dont even try.
Are these bushings filled with fluid? And do you get a CLUNK sound from them when you hit the gas quickly, like jerkin the car with the has pedal? Why do you need to change yours?
Can you be more specific about which gasket you are referring to?
For applying the sealant the tubes sold at the dealer can be inserted into a hardware store caulking gun - funky but it works and makes it easier to control the bead size. Date the sealant. It is only good for about 1 year.
i like to ask vince what symptoms did you have that you changed the diff bushings? And pj why do you want to change them? Like to know and I'm sure those that will view the post will be curious too....
Oh and yes as is typical MB procedure, you need a special extraction tool, but probably can make your own. I'm just wondering if you can do this extraction and reassembly with the diff in the rear subframe
Reason I want to change them is because when I pry them with a lever they squeak badly. But I sprayed some grease to them and they no longer squeak. But, as I was prying them one leaked a black fluid. So now I just want to replace them.
