F&R Dual Calipers
Old May 12, 2019 | 01:16 PM
cm60k's Avatar
F&R Dual Calipers
Just installed dual Fronts (8/6) & Rears (6/4) calipers in 00 "C200",,
sorry for poor pics..!!
-;ZAYED;-
Old May 12, 2019 | 02:05 PM
brad_c43's Avatar
'99 C43, '88 560SL
WHAT?! I need this in my life. How is stopping performance vs stock? What is needed to do this swap?
Old May 12, 2019 | 04:57 PM
DRBC43AMG's Avatar
Whaaaaatttttt? Jeez that must rip the road surface when stopping. Zayed, now we understand why you have been very quiet on here these last weeks
BTW what make are the yellow pads? Pagid, EPC. or .....??
Old May 12, 2019 | 07:29 PM
cm60k's Avatar
Needs so many things bro.,
"cutting with making holes on many places in F&R spindles/made 2 Front brackets & 4 Rear brackets with special titanium flat head screws/T-type brake fitting adapters with banjo hoses/S210T Rear hub & bearing to handle the weight"..
-;ZAYED;-
Old May 12, 2019 | 07:31 PM
silverc4s's Avatar
99 C43, 73 911 targa
Zayed,
were you able to retain ABS?
overall, brake fade should be much lower over track time, braking up to tyre limit of road adhesion present, and unsprung weight up quite a bit.
I hope that’s a big honkin’ V8 in that white beauty...������
Old May 12, 2019 | 07:32 PM
Benzrider17's Avatar
C43 c55 C63
WTF DAMN THATS THE CRAZIEST THING IVE SEEN ON A W202
damn that’s 16 brake pads
Old May 12, 2019 | 07:33 PM
cm60k's Avatar
You got me Daniel,
All pads are EBC Yellow stuff,
my mind twist over with this hiphop project..,
Really really damn hard job, i spend three hours in spa massage to forget my back screaming..,
i can't keep stock M/C & booster, replace them with "R230 SL600", with some minor works with "wiring/lines/hoses",,
brakes are sooooo aggressive, can't imagine how spaceship brutal stopping power..
-;ZAYED;-
Old May 12, 2019 | 08:19 PM
cm60k's Avatar
there're (20) brake pads..
Old May 12, 2019 | 08:28 PM
cm60k's Avatar
Originally Posted by silverc4s
Zayed,
No problem with ABS or even unsprung weight to the braking limit bro.,
while the pressure sensor reads properly back signals from "ESP" to the "ME2.0/ECU",
cause this 4cyl. "C200", doesn't has "ESP/ABS" additional module,,
module attached to the "ABS/BAS" pump..
-;ZAYED;-
Old May 16, 2019 | 02:44 PM
PJmak's Avatar
We need a video of 60 to zero stopping performance
Btw are you in Abu Dhabi?
Old May 17, 2019 | 01:47 PM
cm60k's Avatar
Sure bro., i'm in "Abu-Dhabi",,
While it's 4cyl. i'm not that interest with performance brake limit,
but I tried it once,
when i hit the brake hardly around 50 mile, waaaaaaaa, i felt rear subframe hit my head..,,
i can't use fully brakes constantly, it will harms everything..
-;ZAYED;-
Old May 17, 2019 | 04:22 PM
PJmak's Avatar
-;ZAYED;-
Do you know "alyehli amg" hes over there. Some sort of classic amg dealership looks like.
Is it a legit place? Im trying to buy something from him.
Old May 17, 2019 | 05:11 PM
cm60k's Avatar
Yeah, i meet him once, nice & friendly,
his little bit far from me, but he got unique items & many good AMG vintage parts,,
do you need something from him..?
-;ZAYED;-
Old May 17, 2019 | 06:20 PM
PJmak's Avatar
-;ZAYED;-
Yea man I do but wasn't sure I can trust him.
You think I should just go with it and not worry??
Old May 17, 2019 | 07:15 PM
cm60k's Avatar
As i heard; his so flexible & trusted, but can't assure that to you,
i know a guy that know him personally,
can talk to him about it,,
do you need something pricey from him..??
-;ZAYED;-
Old May 17, 2019 | 07:37 PM
PJmak's Avatar
-;ZAYED;-
Yea its one wheel. Will cost me around 700 usd shipped. If you can check for me man that would be awesome.
Old May 19, 2019 | 11:31 AM
cm60k's Avatar
He bro.,
i talked to my friend, he said; you can get anything from him,,
once you order from him, let me know, he will follow your order & take care of it..
-;ZAYED;-
Old May 19, 2019 | 12:56 PM
PJmak's Avatar
He bro.,
-;ZAYED;-
Thanks man. I apreciate you going out of your way
Ill hit him up tomorrow.
